- Dec 14, 2010
Hello,
I too am interested in NFB10SE for my Sennheiser HD595. If I get it, I will definitely make the balanced connector mod. My question is whether 10SE is an overkill to low impedance HD595. Kingwa has suggested NFB12 to me. But I am very tempted to try the complete balanced setup which should give 10SE a longer ownership considering future can upgrade and/or using it as a pure balanced DAC.
Personally IMHO Audio-gd's headphone amp design is superior than many of its competitors. This raises my next concern that 10SE lacks analog input which prevents it from being a standalone headphone amp in case crazy 32bit/384kHz recordings + fancy DAC become available in the future.
To give my question a better context, my environment will be foobar2000 + kernel_streaming/wasapi + USB + NFB?? + HD595 for now.
Thank you for your advice.
The NFB10se s a better sounding amp than the NFB-12 is, but it's not the be-all, end-all amp. It's capable, fast and will drive anything. I think it's a bit bright and has an edge in the upper midrange/lower treble that can make some female vocals glary.
If you're looking to play 'crazy' 32bit/384kHz recordings, you're not likely to be running them thru a $499 amp given that any DAC that will play then at 1st will cost much more than that.
This is a capable budget all-in-one balanced DAC/Amp. Choose to buy it or not based on those features, not whether it might harm your ability to play not-yet-available source files.
I am curious tho...what leads you to the conclusion that "Audio-gd's headphone amp design is superior than many of its competitors."?
