tme110
- Jan 21, 2011
I found optical very sensitive to jitter but not COAX in fact I've found COAX to be the best overall fit for getting full capabilities and not having signal/jitter issues.
You like it better than your Apex and MApletree?
Guys, please help me out. Ideally I want an all in one DAC/Amp for my T1's and later perhaps HD800 and LCD-2's but holy crap, it's mind numbingly difficult to get anywhere with these decisions. The market is so crowded. Every day I get recommended like 2-3 new products. Basically, I'm after a warm, full sounding all in one with a tubey sort of sounds (to null the high peaks of the brighter cans and add some body and smoothness). Is the 10SE up to that? How does it compare to the Audiolab M-DAC? I'd be using the amp built in.
I've scrubbed off the Benchmark DAC1, NuForce Icon HDP and a couple of others after hearing they're a bit more clean or cold sounding, whereas I'm after something slightly warmer. Also read that the Schiit Bifrost is similar sounding which is why I'm not sure about my Bifrost+Asgard combo any more.
Thinking of running it through a Macbook Pro via USB and SPDIF from my PC sound card.
Can anyone advise me? I'd be truly grateful!
I also hate the Benchmark sound, so I would try wolfson and pcm1704 based dac's first. But its impossible to predict what one prefers, famous speaker designer Lynn Olsen said it important to get advice from people who have similar hearing preferences but they are hard to find. I think you may want to start with a NFB-12, I am a tube guy but it is very impractical to build a full tube amp that can swing 10Vrms into headphones. You have a fairly voltage hungry phone and want to buy a current hungry phone, going to be difficult to find a tube amp that really performs with both of these phones. I think the NFB-12 has a nice full sound and at only $200 for a DAC+amp it surprised the heck out of this tube guy plus you aren't out a lot if you don't like it, it measures like a decent tube amp with basically just 2H distortion but what makes it unique (and the 10SE) is that the sound signature doesn't change with the volume position and it really has a lot of power, it doesn't have NFB.
I was under the assumption that the NFB12 amp section was just half of the 10SE's so I am confused as the NFB-12 is not neutral rather warm and full and of course you can change the digital filter and upsample with your mac to change the hf roll-off. See the thread about it. For the opposite end of the spectrum you could get a $100 O2 which is completely neutral, then you could spend your money finding a good tube dac.
Your post just caught my attention with the mention of the Benchmark and the 600 ohm headphones, the NFB-12 was really the first amp I was satisfied with my 600 ohm AKG's and it would have the current to drive LCD-2s and of course enough power for hd800's (but I think you should also try $100 MS1's as you may be a Grado guy and not know it.)
If we only use the RCA or 1/4' headphone output, is the NFB-10SE wasted or not fully utilized?
The NFB-10SE is a real balanced output DAC and headphone amp, it has balanced (ACSS, XLR and balanced headphone output), single-ended output (RCA and 1/4' headphone output). There are 4 ACSS amps in the NFB-10SE for balanced output, and balanced input, so even through single-ended output, the all WM8741 DA chips will perform fully.
I got my neutrik adapter kits and have been listening balanced for the past 3 days with some homemade canare cables. The most notable change is a lot more bass presence, which is welcomed. Beyond that it seems to make it generally better in every way I mentioned in my initial impression a few pages back.
My listening level went from high gain @ ~10 SE to high gain @ ~2 balanced with the same content. I did notice some of the harshness in the upper frequencies on some recordings right when I got it; this has definitely softened as I approach the 250 hour burn in period.
