Ordered! Should take 7 business days according to Grace.
Still thinking if I should go for the 6 db boost, or should I do 3 db? or just vanilla? Kingwa said 6 db boost should be okay with everything. As long as there's no additional noise I am good. Anyone knowledgeable feel free to chime in.
Congrats on your future end game setup.
Consider getting the rj45 to hdmi upgrade if you plan to use a USB transport in the future.
I'm using a heavy modded gustard u12 with i2s hdmi.
And I ordered the +6db gain stages and installed them myself. Definitely the perfect choice! No noise, just brute power with finesse. Ideal gain if you listen to super low efficiency cans.
What headphones do you use? Likely you don't need the upgrade...the m11 is a beast as is.
But my he560's need a bump on some very select classical music. I still never listen at max.
Before the mod I only listened at 99 onetime on one song. But mostly am around 65/100, and classically around 78-82 with the +6db.
My he-560 are not efficient.
The oppo pm3 is around 28/100 maybe 35 on some select classical music.
You won't hear any more noise by increasing the gain at such small amounts.
If you have clear power, don't worry.
I use ps-audio ps300 ac regenerator (mw2) for pure sine wave goodness.(ps audio lab cable too) Black black blackity black noise floor at high gain. Nuff said.
If you have he6, just get +9 db and be done with it. Makes sense.
There is so much room to adjust in the volume control for even sensitive cans/iems
