Look at my above post.............
About volume curves.
You don't have a 2015 nfb-28
I have never had heat issues with the nfb28
The m11 is a much larger amp and runs full on at all times like solude says. That's pure class a for yah!
But I believe my home being so darn hot and it ran for 2 days without a fan, it got hot with the days we have been having here. 90 ish.
So whatever. Not going to go through this whole thing again with you. Read the graphs and you will see, or just borrow someone's nfb28 to see how loud ya need to crank it to get to your comfortable levels with your 2014 model.
We went over this. It was a combination of the extremely different curve and me using foobar with replay gain on by accident. It affected my gain significantly. Do you not recall this conversation? I thought we cleared all that up. And if you look at the m11 volume curve you will find that it's even more aggressive in the volume curve Being nearly the same all the way to 45-50 and then bouncing a little at 60. I listen about 65 most the time and 80 sometimes with certain classical. So whatever , don't care at this point. You can try my m11 if we ever meet at some event. I would be happy to show you my ears are in order and I'm not blowing them up. I do listen about 4-6 Db louder than some people. At least that is the case with my fiancé. She prefers less volume. I listen at most one or two tracks at levels around 95-98db and mostly around 80-85db for most listening. The loudest I've ever listened to one track was just over 100db at 102db. That was uncomfortable yet awesome at the same time for that particular track.
What's my problem, I should listen to stuff with less volume?
Jriver still is quieter than all other apps. Replay gain isn't enabled and no filters.
It's odd.. I have YouTube videos at 20% and they are loud. I have to crank the amp down to 50 for YouTube videos to be 100%
I'm rambling and done talking about this.
