Audio-gd Digital Interface
Apr 21, 2013 at 8:57 PM Post #3,766 of 4,156
please someone help me, i'm desperate!!!!!
mr kingwaaaa
Connect the USB device and power on, uninstall the driver and restart the computer.
Open the device manager , find the USB device , click update the driver ---> search the driver by self ----> find the driver folder ------> viaudusb ------>Driver ------ WinXP (for 32bit XP and Win7, WinXP 64 for 64bit XP and win7 ), click OK or confirm.
Apr 22, 2013 at 2:28 AM Post #3,767 of 4,156
ok, thank you
after that, pc changed the drivers from USB SPEAKERS in AUDIO GD.
And now how can I install control panel and other features?
if I try to launch SETUP.EXE, there's no way to do that, I Always receive an error code
0xE0000203, 0x0
and then
please check the device is well plugged in
but it's well plugged, no doubt
I use audiogd usb cable
Apr 22, 2013 at 10:33 AM Post #3,770 of 4,156
Do you have a spare HDD?
Try a clean install of Windows, and then install the DI drivers to see if it is the other software/drivers in the Windows that stops the DI-V3 from working.
I would use this method to isolate the problem of Hardware and software.
thank you jimmychan
maybe some friends can help me with a separate hdd, and we'll be able to understand if the problem is on the hardware or software side
Apr 23, 2013 at 12:40 PM Post #3,773 of 4,156
I've found a guide about "how to disable automatic driver installation in seven"
tonight I'll give it a try: uninstall drivers, clean up the pc and disable automatic driver installation.
at this point I'll try to download audio gd new drivers...and see what happens
Apr 23, 2013 at 5:56 PM Post #3,775 of 4,156
ok, i give up. can somebody please tell me how to execute something that will display a control panel for this thing in WIN 7? after working at this for 8 miserable hours, I have associated the correct driver to the device. but since the initial load failed when running setup.exe, I have no icon to accomplish starting this thing up.
H E L P
Apr 23, 2013 at 6:26 PM Post #3,776 of 4,156
Anyone know if you can get a USB32 kit for older usb units from Audio-GD?
I believe so but it's like these upgrades....NOT plug and play....Mods are required for most older dacs.
http://www.audio-gd.com/Pro/dac/TE8802/TE8802kitEN.htm
Drop Kingwa an email to verify.
I believe you can wire it directly to the DSP module (if your DAC has one) but then you'll loose your S/PDIF (coax and optical) connections.
I was thinking on picking up a spare DSP module to try it but in the end I figured the DI V3 would be a better choice for my DAC19-DSP.
Of course my goal was to eliminate the S/PDIF to I2S conversion.
Apr 23, 2013 at 6:50 PM Post #3,777 of 4,156
H E L P
great - I executed setup again and it completed successfully this time. reboot and have some panel displays. BUT I have 24 bit but no 96K...????
Apr 23, 2013 at 6:55 PM Post #3,778 of 4,156
H E L P
apparently i'm in the same boat as angel72, who i'm sure is a very nice person .... but this sucks. grrrrr.
Apr 23, 2013 at 7:28 PM Post #3,779 of 4,156
I just reinstalled my nuforce u192s usb-s/spdif converter and , as it did originally, it works just fine.
there has got to be a bug of some sort in this audio-gd driver that we're being instructed to use for win 7 32. it seems unlikely that 2 of us would have the exact same troublesome results if there were not an issue with the driver software, especially when all other audio drivers work as they should (i've tried both a nuforce and a yulong usb driver successfully.
i would really like to be able to get this device working, but wiping my system clean of other software drivers seems a bit above and beyond the call of an end user. .
angel72 - any luck?
Kingwa - any ideas?
Apr 24, 2013 at 3:33 AM Post #3,780 of 4,156
NO LUCK, I'm soooo angry!
my last experiment, I wrote about it few posts above, had no success: probably it would have gone fine if it was the first attempt of connecting the audio gd to the pc.
now I'll try a clean install of Windows,  with an external hard disk, as suggested by jimmychan
or sell everything, I'm so bored...
