Got my DI-DSP, DI-PSU, 2x TCXO. Sounds good. Async USB not working on SBT.
First impressions:
I have to precise, that I hook it between a Squeezebox Touch and a Reference 9 DAC from audio-gd:
SBT -> spdif -> DI-DSP -> spdif -> RE9
So. I did not expect the difference to be extremely big. As Reference 9 already features a DSP1, that does, as far as I understand, a similar job as DSP 3.1. inside the DI-DSP.
First impression: a bit harsh. However, this could be a question of a bit of time until it gets breaked-in. Kingwa sais, that it makes an effect in particular on the clocks.
Bass appeard stronger and a bit tighter. But apart from that the differences were rather subtile as expected.
Then I set it to upsample to 96khz.
WHAT a difference on 44.1k -files! More detail, much tighter bass, much more "to the face" character of the sound. Trebles shrill, depending on the recording. Maybe just more revealing.
I will let it burn in a bit more, until I make more precise 1:1 comparisons with the DI-DSP in place and the direct connection to RE9.
HOWEVER: I tried to get async USB connection to work. That is, in fact, one of the main reasons I got the DI-DSP, because it has the TE8802L - USB - input. This might overcome some shortcomings of the spdif - output of the squeezebox touch.
It did not work. Althoug I got a test-firmware from the vendor of the TE8802L, that is supposed to make it Linux-compatible. It worked on 44.1k - files, but based on the log-outputs it suppose, that transfer was synchronous, not async. And higher resolution files crackled awefully. So I have to wait, until Tenor developps their firmware further for more compatiblity to Linux-platforms - in particular the SBT.
Cheers!
