sfogar
- Oct 20, 2006
Mandatory ASRC looked dubious anyway.
Yes, I know but it seems the case...
Best
AF
So definetly there's a problem with Sabre Dacs with no upsampling which is 'cured' by the upsampling, I don't know how ...
I don't understand how you came to the conclusion that the DAC is the problem if upsampling on the digital interface fixed it. I have gotten dropouts playing native 24/96 files before too.
Not sure if I have descended to the insanity of CMP build guys though
Elaborate more on the upsampling and how you finally got it to stop...
I've stopped using my DI + PSU for more than 2 weeks now since I was never able to solve the issue...just straight into my NFB-10ES via USB which works perfectly fine, except for the slight degrade in sound.
Hi,
Well I tried mainly cause Drez already found that using upsampling dropouts stopped...
Since I changed to upsampling not even a single dropout...
You have to open the top cover of your DI with a screwdriver...
Then you have to set the jumpers...
AF
