Thanks to you. This mod should be quite easy. I will try to save the orginal oscillators, that should be a bit tricky. I will alternate the de-soldering between the two txcos, and try to drain the heat somehow.
chipquik might work too...but remove as much solder as possible first with a wick.
let it fully cool after you remove the solder.
chipquik is pretty sweet, keeps the solder in liquid form for a long time so you can pull the crystal out. it's very low temp too.
https://www.youtube.com/watch?v=7kyaz4Zrd78
good luck. the breeze truly should be a breeze to do. just be careful to not damage the traces on the pcb.
or try something to this effect.
https://www.youtube.com/watch?v=gSzfNrbDfIY
