robertsong
also...get some bypass caps to solder to the bottom of the boards...this can be done with a sra low temp solder past and hot air tool set to exactly 170C
http://www.digikey.com/product-detail/en/GRM2195C1H103FA01D/490-8295-1-ND/4380589
these bypass caps are very nice
on the bottom of the rhea boards are two contacts, add approx 1mm square of paste per contact, use tweezers to drop the murata cap onto the two contacts perfectly centered. use the heat gun to flow the solder, once the solder turns to shiny silver, let cool for about 20-30sec. clean left over flux with pure 99.5% alcohol.
SRA low temp solder can be found on amazon. its awesome stuff, I do all oscillators with this stuff. since they are super sensitive to heat...except those huge oscillators....
Thanks. Are the bypass caps mandatory? I don't have the tools to accomplish that. Wouldn't Twisted Pear add these on?
