If you run (ANY !!) process many times, after each other or in parallel does not matter, the uncertainty or errors in the output of the process will improve with the function of SQRT(n) where "n" stands for the number of events. This trick can be used for example to get very precise resistors or capacitors by paralleling them. Thanks to the current source output we can easily do the same for the TDA1543.......
Is there an optimum? I am sure there is, but I was not so crazy to try all possible variations of "n".... I tried in a prototype 3 DAC's in parallel and this was a major improvement. The low level detail, known from high bit systems was really improved. Listening to the 8 DAC version, it comes very close to SACD.... not bad I think (again an understatement...
So how many is realistic? well for each doubling of improvement, which equals 1 bit extra of linearity we need to multiply "n" with 4 !! so with 8 I get one and a half bit extra, which actually is already very good. If I want now 4 bits better performance I need to put 4x4x4x4=256 DAC's in parallel. This will consume 12A supply current and dissipates 100Watt. Feel free to do so, but it seems a bit unpractical to me, not even mentioned the circuitry needed to drive the 256 TTL inputs !!! Why did I mention 4 bits? Well, according to the datasheet, the 1543 is aprox 12-13 bits effective. A PCM63 by the way is also not much better then approximately 15 bits effectively. All the rest is marketing
So the choice for 8 is purely based on a combination of maximizing "n" and keeping things within reason technically.........
There is also an additional EXTRA bonus by doing this: by paralleling the DAC's we have to decrease the R(I/V) resistor as the current increases. So the Output Impedance is also reduced by "n". This helps a great deal driving the interlink to the pre amplifier of directly to the end stages if you do so...
Furthermore, the DAC pinning makes is possible to just piggy back them..... this resulted in the "cool tower" you see in the pictures.........
Can you actually measure the improvement? Oh yes, no problem ! below, from left to right the 2 results of 1 DAC and 3 DAC, which is almost 1 bit improvement. Both Measurement at optimum. You might think, the difference is low, but this is exactly (3dB is 0,8 bit) what helps the low level detail to play at less distortion !!
I stole this text from
a web page, I did not write it. so I cant answer tricky questions, Sorry.
