tim3320070
Kingwa can explain- he did for me a while back.
This unit has a automatic switch that gives priority to the BNC if a signal is present there.
Now when I try to measure the BNC resistance I get 25 ohms, I am assuming this is because the switch isn't engauged when I am measuring.
Has anyone opened their 3SE and confirmed a good 75 ohm termination on the BNC input?
Originally Posted by jimmychan /img/forum/go_quote.gif
You should go for REF 1 or 7, because it was designed for 8 DAC chips.
he wanted a single ended dac that uses 8 chips, not a balanced one. using the ref 1/7 single ended would only be using 4 chips.
According to Audio GD, that is not true. When asked, he replied that the Ref 1,7,8 would still make use of all the 8 chips with RCA output and sound a bit better than the Ref 9.
It's here...finally
The long customs delay even paid off in the end: the charges were much lower than I had originally anticipated....a first for me!
Since I came home late today, I didn't manage to plug it in yet, so you'll get no initial impressions from me just yet.
Probably not even in a few days or a week, I will need some time to compare and verify my findings.
Instead, just some quick shots of its arrival:
P.S.: I hope the OP doesn't mind me hijacking his thread like this!
Otherwise I can also fabricate a title for yet another audio-gd thread...it's just that I feel there are far too many of them already.
Shamelessly bumping this thread, but how much did you pay for customs? I'm considering the 3SE as a DAC upgrade and need to take customs into the consideration as well.
