DJtheAudiophile
- Dec 7, 2016
Question, would the Sine fit flat in a Pelican 1170 case?
Should I buy the Oppo HA-2SE or the Astell & Kern AK jr. To go with my sines for mobile use?
Can anyone compare the Sine on ears to the Kef M500 in comfort? How is the clamp of the Sine after breaking them in and a little bit of box stretching? Can they become comparable to the M500 in comfort?
Thanks!
Hi guys just got my Sine 3 days ago and I am in love. Coming from the Mad Dogs, these definitely need amping. Any recommendations for a portable amp or amp/dac combo in the 150-250$ range?? I am running them through an LG v10. Atm my pick is between DFR or Cayin c5, fiio e17/e18.
The Sine does sounds good directly from an Iphone, but sounds better with the Cipher, even more better with a Mojo and then so magical out of a pure analog tube desktop headphone amp like the Mapletree Audio Design!!!
Annoyingly(to me) the cypher adds a small bass shelf boost. I wish that were optional, along with the soft clipping compresion.
Have you tried the iPhone 7 lightning adaptor? I found it better with the sines than the iPhone 6s. Maybe the lower output impedance helps.
I'd need it to be portable though and it seems the Dragonfly can only be used on a pc. But it is a very nice piece of gear . I've decided im going for the Xduoo XD-05 as it will power the Sine far more than enough but i'm also going to swap the stock OP amp for the Burson V5i as many people say it improves the sound a good bit and beating out the Oppo HA-2 SE. I did get the chance to listen to it but in stock form and it really did impress meIf you are looking for tighter, controlled bass with good sub bass extension plus a little more sparkle with the highs, I would recommend AQ Dragonfly Red at $200.
