YesIs latest firmware is still 0.1.10?
Audeze Penrose X and Penrose
- Thread starter Audeze
L11R
Yes, you can use this URL to check the latest version:Is latest firmware is still 0.1.10?
https://audeze-penrose.s3.amazonaws.com/AudezePenroseFW.xml
waltdisneypixar
This XML file does not appear to have any style information associated with it. The document tree is shown below.Yes, you can use this URL to check the latest version:
<data version="0.1.10" persistent="https://audeze-penrose.s3.amazonaws.com/FW_V_0_1_10/AmberX.persist.cfs.bin" params="https://audeze-penrose.s3.amazonaws.com/FW_V_0_1_10/AmberX.params.cfs.bin" firmware="https://audeze-penrose.s3.amazonaws.com/FW_V_0_1_10/av3595_baker_app_fwb1.cfs.bin" data="https://audeze-penrose.s3.amazonaws.com/FW_V_0_1_10/AmberX.data.cfs.bin"/>
what site is that?
This is the URL that the audeze apps check to see if there is new software available; it's not really a "website for humans", but a file hosted by Amazon S3 (a cloud storage system).This XML file does not appear to have any style information associated with it. The document tree is shown below.
what site is that?
God, i just got a replacement unit from Audeze in order to try fixing my Bluetooth problems (completely unchanged), but now i get the left ear wooshing that other people mentioned (now i understand what it's like, it's really like wind noises)...
EarlZ088
When does this wooshing sound happen, only during certain frequencies are played?
jameswalker
At all times, for me a few mins after they are first powered on for the day.
Hello. Not sure if anyone has dug into this....do you get it when:At all times, for me a few mins after they are first powered on for the day.
Wireless dongle
Built in Bluetooth on PC/Mac
Bluetooth mobile device
Physical Aux connection
All of above with microphone switch physically Off and On
For the record I get a very slight background noise, kind of like listening into a sea-shell unless I physically turn off the mic. This happens regardless of connection and regardless whether microphone is plugged in of not. Turning off the sidetone mic-monitoring diminishes the sound. Turning down the gain of either sidetone monitor or the microphone itself has no impact at all.
This is leading me to believe that at least for the lower seashell effect it's the microphone gain/monitoring circuit which is at fault.
Anyone tried any better windsocks for the mic? I get breathing noise and I want to keep the mic close to my mouth for clarity. Anything better out there?
jameswalker
Move the mic further away.Anyone tried any better windsocks for the mic? I get breathing noise and I want to keep the mic close to my mouth for clarity. Anything better out there?
HiAnyone tried any better windsocks for the mic? I get breathing noise and I want to keep the mic close to my mouth for clarity. Anything better out there?
I only get heavy breathing if I position it incorrectly.
Suggest you read the positioning instructions in the audeze website technical FAQ if you've not already, and then experiment.
The microphone is incredibly directional.
I think you'll want it somewhere just to the left and away from the lower part of your chin/jawline and pointing only at your mouth. Not up or in airstream from your nose.
Just imagine you're Janet Jackson and then move it slightly from there
Regards Chris
In my case, i noticed it when i was not playing anything (and mic switch was off)When does this wooshing sound happen, only during certain frequencies are played?
So is anyone using a 3rd party mic? Does it make it any better than stock?
I did briefly, before the latest firmware update. It was less muffled with the old update, but on the new update the mic it came with sounds better now. 1.10
jameswalker
I tried 2 other mics and have reverted back to stock.
Total: 14 (members: 0, guests: 14)
