- Apr 16, 2013
I think that only works if the USB port is part of a hub(that has more power running through it). But hopefully it charges all the time ._.don't these charge via USB if you're using your PC as source?
Edit: Looks like anything will work... "You can use any standard 5 Volt USBcharging output for Mobius, such as a mobile device charger or computer USB connection."
Battery rated for 10 hours, but should last longer if 3D is turned off. Cool. But I'm gonna be wired all the time lol.
"Note: Battery life and charge time will be affected by many factors, such as your solar system's magnetic/gravitational pull, RFI/MFI levels on your particular starship, etc. Time travel may have an adverse and disproportional effect, and may shorten battery life by a considerable margin. Please be advised that Audeze's warranty agreement does not cover damage due to time travel."
