- Mar 20, 2010
My friends have problem with Cloud Orbit. I checked computer see correctly this headphones, I also checked whether the current flows along paths, cables, whether it reaches transistors and batteries. But Cloud Orbit won't turn on, they're dead.
What could be a problem, battery or something else?
Contact HyperX support, as we do not handle their products, but it just sounds like the battery might be dead. Batteries should be manufacturer replaceable.
I upgraded from Win 10 to 11. And My Mobius headset is detected as "speaker" rather than headset/headphones. And I cant change it via the windows device configuration. All I can select there is "Stereo".
Not sure if this is normal? I tried pretty much all I can think of. Removing from device list, re-installing HQ etc.
https://i.imgur.com/rq5Y50j.png
https://i.imgur.com/AGS28Nn.png
Please follow what FlavioWolff posted.
High resolution mode is stereo only. I think you need to change the headphone to 7.1 mode:
"A three-second press of the Microphone Volume Control will toggle through the three audio resolution modes available via USB connection. Those three modes are as follows: [...]"
https://audeze.zendesk.com/hc/en-us...-1-channel-to-2-channel-or-Hi-Res-Mode-in-USB
Thanks for the assistance.
i'm back after few years, entering in the 5th owner year with my beloved headset
it's the longer lasting component ever bought for my gaming machine and i want to keep them neat and tidy!
do you know if is provided as replacement, the sponge for the headband?
We sell replacement ear pads on our accessories page, though we may only have carbon color accent on the pads now.
