I recently got the Mobius . I’m on a very old firmware it seems,1.30, Audeze support made the removed version available to me with the caveat that there is a small possibility of bricking it.
I’m in another continent hence jittery .
I have a few questions for the experienced users if Mobius in this thread
1. What preset do you suggest for 3d 7.1 usb sound for 7.1 sources ? Is it a huge difference from firmware 1.30 to 1.71?
2. I have a windows 10 v1903 build 18362.10014
Intel X9980XE
Msi X299 creation board
Usb connected to intel usb c port on the motherboard . (Additionally asmedia ports are there too)
What do you think are my chances of hitting a glitch ?
Advance thanks for any answers . Cheers
Thomas
If you fear to brick your Mobius don't do the update, wait for a confirmed stable version.
The changes might not be worth the possible hustle, they improve the experience by not more than 20%.
The main changes up to Firmware V5 are:
- Addition of a so called "Warm" preset, which boosts the bass and cuts the treble more than the others.
- Correction of left/right frequency response differences caused by different acoustic properties of left and right cup.
These corrections boost the bass compared to the V1-V3 presets, now "Flat" sounds about what "Music" was before.
- Addition of the possibility to use the HRTF without head tracking, called "3-D On".
Not much use on my side, as head tracking is what really makes the 3-D experience work for me.
- Improved behavior of the head tracking.
- Microphones noise gate is removed, and microphone gain seems to be slightly boosted.
At least, the primary problems with the microphone seem to have been solved, there are no more complaints about it.
I can't tell much because I don't use the microphone.
- Fixes of several smaller bugs that appear under certain circumstances. Nothing that would stop you from using the Mobius.
First become familiar with your Mobius.
If you want to use the 3-D mode (the main reason someone would buy the Mobius), I strongly suggest to precisely set up your head dimensions in the Audeze HQ app for best experience.
Personally I reduced the room setting to 22.3 to bring down the reverb to a level that is usually not noticeable with music.
Which preset to use depends on your personal taste.
I mostly used "Music" with "3-D Manual" before FW V5, now I mainly use "Flat", with "3-D Auto".
If you really want to do the update, follow all the advice patiently and slavishly.
Take your time!
First make sure that you have a
really stable connection, computer- and cable wise.
The supplied USB-C cable tends to make problems here.
Test it by slightly wiggling on the connectors on both sides, while running music.
An unstable connection during FW update will brick your Mobius.
If the connection is reliable, precisely run through the process without disturbing it.
There is no shortcut!
