clerkpalmer
- Dec 16, 2015
I know you directed this Audeze, but I believe unfortunately the answer is you need to find a Windows PC to do the update. There is some discussion about this above and Audeze said there is no way to update via Mac and nothing planned.@KMann & @Audeze I'm sorry to repeat this question, but I did not get any response the first time I raised it, which is why I am having another go at it:
What should Mac Users do regarding these firmware updates? I almost exclusively use my Mobius on Mac Computers, although I have one windows computer that I use for occasional windows exclusive tasks. It is what I used to configure the Mobius when it first arrived. Now I have the Mobius App on that computer, and also on my Macs.
If the update can be done using my Mac computer, then there is no problem. However, formal instructions seem to exist only for doing the update on windows, so I am assuming it can be done using only the windows computer. But then, in that case, the question arises as to how Mobius would work with the App on the Macs once updated on windows, as if to be used with the App on Windows. Will the Mobius still be compatible with the App on Mac after such an update?
Bottomline : If I use my Mobius exclusively on a Mac, should I even consider any firmware updates, or should I ditch the idea altogether?
Could you kindly advise, as to what the "best practices" are for Mac users, when it comes to firmware updates?
Thanks.
Edit Kmann beat me to it.
