HolyGeesus
Has the volume been limited with the latest firmware? They certainly seem to be quieter than before here.
I can not confirm that for V2, if they did not change something in V3 the volume is exactly the same, I did my measurements with exactly defined level through USB.Has the volume been limited with the latest firmware? They certainly seem to be quieter than before here.
There has been no change in gain. Perhaps you are in a different mode or EQ preset? Wit the latest firmware Mobius remembers the last settings after power cycle.Has the volume been limited with the latest firmware? They certainly seem to be quieter than before here.
If you’ve been reading this thread you'd know it's already official via the audeze app and website. Unfortunately it doesn't mean it's bug free.After reading this thread lately,it seems like the firmware upgrade is unstable and its best to wait for an offical realese.One that are on the audeze mobius app.
Then it has pass me by But i cant find it on the app or website
NO. If you are on v2 or v3 public Beta, do not update firmware. Especially if you have '3D on' or 'Tracking off' option. Upgrading will result in you loosing those options.Is the release v3 firmware identical to the last beta? Should the Mobius be updated if it has the v3 beta firmware on it?
@sahmen -- Sorry I thought we addressed this earlier. Firmware update requires a driver to put your Mobius in programmable mode. However, the drivers are not available for MAC (and we do not foresee it happening in the future either). So you will not be able to update firmware for your Mobius using a Mac.@KMann & @Audeze I'm sorry to repeat this question, but I did not get any response the first time I raised it, which is why I am having another go at it:
What should Mac Users do regarding these firmware updates? I almost exclusively use my Mobius on Mac Computers, although I have one windows computer that I use for occasional windows exclusive tasks. It is what I used to configure the Mobius when it first arrived. Now I have the Mobius App on that computer, and also on my Macs.
If the update can be done using my Mac computer, then there is no problem. However, formal instructions seem to exist only for doing the update on windows, so I am assuming it can be done using only the windows computer. But then, in that case, the question arises as to how Mobius would work with the App on the Macs once updated on windows, as if to be used with the App on Windows. Will the Mobius still be compatible with the App on Mac after such an update?
Bottomline : If I use my Mobius exclusively on a Mac, should I even consider any firmware updates, or should I ditch the idea altogether?
Could you kindly advise, as to what the "best practices" are for Mac users, when it comes to firmware updates?
Thanks.
