@KMann ,
@Audeze
I miss some things in (V3) that were largely discussed here for a new firmware, see lists below:
- A fix for the channel inbalance caused by different acoustic properties of the left and right cup, causing the frequency response to drop off 1-2dB in the right cup below ca. 2kHz, up to 3dB below 100 Hz.
- A fix of the channel inbalance which causes all gaming EQ presets to shift ca. 1.5dB to the left.
In the sum these two create a significant shift of the stereo image to the left.
- The announced basshead EQ preset seems not yet included.
- 3-D Auto sluggish behavior.
- 3-D Manual long term drift to the center.
- Headtracking too strong for some people (like me) in the front +/- 30°.
I did not yet update the firmware as I did not have found the time for the process.
I am now wondering if it's worth to risk the possible hassle. I am already on (V2) and don't have any of the problems mentioned to be fixed in (V3).
The most important fixes for me would have been correction of the 2 channel inbalances, which in the sum generate a problem in daily use for the Mobius, even more in 3D, where an outside/source side correction doesn't fully do the trick.
I find myself using the Mobius lesser these days because of the audio related problems mentioned.
Are these still scheduled for a fix?
FIRMWARE version history, Release notes:
(v3) 2018.11.16:
1. Fixes bugs related charging LED.
2. Changes in voice cues related to 7.1 ch and head tracking
3. Fixes a bug that caused voice cue to disappear when switching from 7.1 to 2Ch
4. Fixes a bug - when powering off in LDAC Hi-res mode, powering on with USB
connected , caused it to put Mobius in Hi-res mode instead of the previous USB mode
(V2) 2018.11.01:
1. Improves mic gain and makes sure mic gain range is set correctly.
2. Improves noise gate.
3. Mobius Channel setting (2ch/8ch/Hi-Res), 3D mode (off/auto/manual) and EQ
presets are remembered on power cycle
4. Other minor bug fixes
(V1) 2018.09.26:
1. Adds a ‘Warm’ presets that adds a warm tilt. Boosts the bass and brings the treble down
a little.
2018.09.10:
2. Mic: Increases Mic gain to compensate for low Mic volume while using Win 10 and Win 8
Microsoft USB audio drivers.
3. Persistence mode: Remembers the last EQ preset on power cycle.
