Here are a couple more suggested features:
*Being able to adjust the audio balance left/right channels, and for 5.1/7.1 content, the audio fade front/rear channels. I've found the rear speakers are top quiet for FPS , and when looking around I can actually loose detail when things are happening behind me.
*User custom EQ presets
*Ability to turn off unwanted presets
*Ability to rebind button layout on device
*User made profiles for different use-cases, selectable by cycling through on device: Bluetooth Hi-Res music EQ profiles, USB 3D gaming ballistics EQ profiles all preset at the switch of a button.
Plenty gaming headsets have user customised profiles, so that could be a valuable feature for people really setting the Mobius up for their own experiences
You can adjust volumes on windows.
Go to sound settings, select mobius. In second tab there should be an adjustment setting /volume level .
It should have a volume line with a button on the right side. Click the button and you will see t he volumes of each speaker.
