Thanks for the tip, had not heard of them yet. I would be visiting Hifi Solutions, which seems to be close by, so if there is time I can check out Headphone Auditions as well.If you are in Amsterdam you can go to Headphone Auditions on Utrechtstraat, Stefan has both of them on hand.
Audeze LCD i4 TOTL In-Ear Monitor Discussion
- Thread starter Emerald Core
They are on the second floor of Concerto Audio (the Linn dealer, not the record store). Great selection of high-end gear! You can check out their website as well.Thanks for the tip, had not heard of them yet. I would be visiting Hifi Solutions, which seems to be close by, so if there is time I can check out Headphone Auditions as well.
Had a look already and they do indeed have a great selection of gear. Lots of stuff I want to try out (Audeze, Focal, Chord). Just a shame that I don't know any stores like that closer by (I live near Groningen) and it takes me three hours to get to Amsterdam.They are on the second floor of Concerto Audio (the Linn dealer, not the record store). Great selection of high-end gear! You can check out their website as well.
bifeo001
- Nov 2, 2016
Have to take care of some debt, so I might have to sell mine. I say this sadly but if any one wants mine let me know.
gonzfi
- Dec 22, 2012
Has anyone used the bluetooth cable/module with the lcdi4 and can they comment on how well it works?
BlueThunder
I’m getting a listen of these, in order to see if I prefer them to the KSE1200. Anyone able to give me a quick MUST DO list?
I don’t have the Cipher cable, but do have Roon so I could probably use the Audeze settings.
Thanks!
Thanks!
EagleWings
Here is how to activate the Audeze presets in Roon: http://kb.roonlabs.com/Audeze_Presets
Here is how to go to the DSP section in Roon: http://kb.roonlabs.com/DSP_Engine:_Accessing_DSP_Engine
I have both and they are different and not necessarily 'better' than the other. The i4 is like a miniature open back full size cans while the kse1200s sound incredibly realistic with acoustic and electric guitars. I love both.I’m getting a listen of these, in order to see if I prefer them to the KSE1200. Anyone able to give me a quick MUST DO list?
Thanks!
I just tried it, works quite nicely. Comparable to the Cipher cable. I ended up buying one.Has anyone used the bluetooth cable/module with the lcdi4 and can they comment on how well it works?
BlueThunder
Does the i4 supplied premium cable attach to the BT module, or do you have to use the cable the module comes with?I just tried it, works quite nicely. Comparable to the Cipher cable. I ended up buying one.
lithiumnk
HelloI just tried it, works quite nicely. Comparable to the Cipher cable. I ended up buying one.
Are you sure that you tried lcdi4 bluetooth cable & not isine ?
I am asking because Audeze rep told me today via email that the bluetooth cable for lcdi4 will take few months to release.
I wondered as well, but checked the package and it specifically mentions LCDi4.Hello
lithiumnk
Thats surprising... btw does your local audeze dealer sells the lcdi4 bluetooth cable online (international shipping)?I wondered as well, but checked the package and it specifically mentions LCDi4.
The Bluetooth will work with the LCDi4 but the firmware isnt for LCDi4 yet.I wondered as well, but checked the package and it specifically mentions LCDi4.
I have contacted Audeze CSupport and they say it's in the works.
