Build, very nice... especially the front rounded edges. Thinner than the X26P. Similar in weight. Both are chonks and dense. Menu is tiny AF. I sit about 5-6 feet away and it's impossible to read, but the volume is nice and big if I could use it. No volume control in NOS or DSD mode, which sucks. Have to resort to Roon volume via HQP.
No manual in the box or online. Someone posted a link to the Chinese one, but I can't read it. Emailed Gustard and they sent it over in English and confirmed fuse is the same size. To be clear, I didn't have a need for another DAC. This just launched and was perfect timing as I was curious about R2R and because
@shwnwllms had me try DSD upsampling on the X26P where I discovered a hiss issue with my unit. So, Gustard has offered to repair even though I am the second owner. I needed another one to use in the meantime because I couldn't take being without it. Thankfully, the original owner had a PO and sent to me. Great support from Gustard so far even though the inconvenience. So, i'll be mailing it off soon.
Sound... still early days. Initial stock for stock impressions are the mid forwardness was less harsh with the R26 than X26P on the LCD5 for me. Like stated earlier, it sounded pretty dang good tonally with the Oor/Hypsos vanilla if that's your jam. But, not the magic I have been having with the X26P and my setup. Goal was to either replicate or improve on that sound.
So far, at least they don't sound the same out the box. As in the carryover of my preset didn't give me an identical experience.
Conclusions so far are that it's pretty soft, kinda diffused and airy sounding in comparison. Not the same solidity in bass note fullness, rounded. Like a sponge instead of a brick. Like how i've read R2R is like unless I remembered wrong.
Over the last couple days and hours, I think I finally found the magic i'm after. I had to dial in more bass and tighten the Q value in comparison due to the softness. I was worried for a sec. that it was too spread out sounding to offer any impact, but I think I got it under control now. This is notable in that presets aren't going to work for everyone's differing chains.
Don't worry, i've got plenty of ridiculous additions to my playlist now.
So, if you haven't already got me on ignore or stopped reading... now time for some more psycho crazy talk that you can skip.
I purposely left the stock fuse in throughout the whole first couple days tweaking and just an hour ago swapped the SR Purple from X26P. Everything is more as I remember and in line perfectly now. Placebo maybe but it seems like the air region was subtly different before it was in.
Conclusion, I was able to find the sound I want with the minor benefit of the very minor separation/stage benefits so it's a keeper.
Testing methodology is with repeatable frisson inducing passages. So I test not only tonal balance but maximum frisson. Tightness of bass and everything plays a role here for perfect synergy.
