Apr 13, 2022 at 9:26 PM Post #4,966 of 7,074
Apr 13, 2022 at 9:36 PM Post #4,967 of 7,074
Can you post the curve for that EQ for me
Oratory's EQ .
For me, Oratory's upper mid and treble settings were fatiguing but that's because the Harman target cannot be relied upon beyond 3 kHz. I'm quite sensitive to too much treble. As always, your mileage will vary.
Apr 13, 2022 at 9:48 PM Post #4,968 of 7,074
Yeah. I can't do that much. I drag the 3k back down a bit, shelf tilt the treble up 2db or so and narrow Q drag 8k down (triggers me). Mids I leave and just add a bass shelf to taste. And by that I mean so much bass i can taste it.
Apr 13, 2022 at 10:20 PM Post #4,969 of 7,074
Yeah, I don't even know why I posted that, it's so useless. So much variation including gear used that you just gotta tweak it by your ears.
Apr 14, 2022 at 1:26 AM Post #4,970 of 7,074
In my case, definitely technical performance/some smoothing over of rough edges.
My recommendation :
Topping E50 / L50.
The performance is outstanding.
Te measured values of both devices are at the absolute reference level.
https://www.audiosciencereview.com/forum/index.php?threads/topping-e50-review-balanced-dac.26219/
The Power output is more than sufficient, and the amplifier is absolutely load-stable even at 15 ohms.
Apr 14, 2022 at 1:27 AM Post #4,971 of 7,074
Apr 14, 2022 at 2:06 AM Post #4,973 of 7,074
Overall I find the LCD-5 comfortable.
But the pads look more comfortable than they are...
Apr 14, 2022 at 2:29 AM Post #4,975 of 7,074
After about an hour, I have the impression that they are pressing everywhere.
If I could express one wish, it would be the pads from the LCD-X
Apr 14, 2022 at 12:18 PM Post #4,976 of 7,074
Lil Session :L3000:
Apr 15, 2022 at 2:27 PM Post #4,978 of 7,074
Apr 15, 2022 at 2:42 PM Post #4,979 of 7,074
My review of the LCD-5 is now live, all ~9200 words of it: https://www.techpowerup.com/review/audeze-lcd-5-planar-magnetic-headphones/
What a wonderful and detailed review!
As first run owner of the LCD-5, I can back up your claims on sonic characteristics you stated, and you are spot on about the EQ. Added bass shelf, a small cut around 1khz, and a bit of treble tweaking are all that is needed to seriously transform the LCD-5 into more of a detail monster than it already is.
Apr 15, 2022 at 6:26 PM Post #4,980 of 7,074
Fun fact. The cable is a normal looking 4 wire. Twisted pairs from splitter to the cup. Those twisted pairs are then just twisted to the amp end connector! Not braided as a 4.
Thank you for listening.
