chargedcapacitor
If you do not plan on using EQ, then I would recommend the iCan Signiture with a DAC of your choice. The Xbass function on it is amazing, IMO. There are tubes, which can be rolled, but I always preferred the solid state option.Let’s suppose you only can spend $6000 in a Dac/amp combo to pair with the LCD-5: what would you guys choose?
I’m from Brazil and the import tax for electronics is (I kid you not), circa 100%. The more portable the solution, the bigger the chance of it slipping through customs unnoticed, but the tax dodging is not my main concern (it is a factor, though).
So far I’m leaning towards the Chord TT2. Also considering: Ifi Pro Idsd signature.
thanks
If you do plan on using EQ, then I might suggest the Ferrum OOR, without the hypsos. It could work better on more headphones and be the last amp you ever buy, with an upgrade option with the hypsos power supply.
