Shembot
- Nov 28, 2014
Hmmm, gold one... https://www.instagram.com/p/y0Sh3nGAVu/
Whoa, I wonder what that is.
Had anyone else noticed that when you put on and take off the headphones, that you get a "crunchy plastic sound"?
I expect I'll do the same when I get the LCD-4, keeping only a closed pair to complement them (my Ether C probably leading the pack there so far).
I love my LCD-4's, sold all of my other headphones due to lack of use.
I was trying to be diplomatic...but here goes:
In no particular order :
SR-009
LCD-4
HE1000
HE Edition X
LCD-X
LCD-3
HD800
HE-6
T1 Generation 2
SR-007Mk1
Top three are as I mentioned before.
Lucky you.I wish I could stand the weight of the LCDs and enjoy their sound like you do, but... I have always found the LCD too UNconfortable to be able to enjoy them despite their very good sound. I sold my LCD-X for this reason despite the fact that I likes it's sound (I even bought the "large headband" designed by a headfier, but it did not helped a lot).
Am I the only one with this (UN)confort problem ???
Thanks. I'm considering trading in my Marantz HD-Dac1 and Audeze LCD-3 for a chord Hugo tt and Audeze lcd-4. When I use my Marantz I set it on medium gain and with the lcd 3's generally have the volume at 25% and by 50% it's almost too loud to listen to. I know the chord doesn't have a gain control and someone mentioned the volume is digital or something like that so a gain control is not necessary? When you use the LCD-4s with the Hugo tt on a stand alone basis how would you describe the volume? I know it uses a lighting spectrum but within the lighting spectrum are you similarly at 25-50% or are you basically maxing it out when you listen to it. Thanks for the feedback!!
how does the spore4 improve lcd4 and he1000's sound. Is it better on he1000 or lcd4?LCD-4 compared to HE-1000
With Silver Spore4 cable by DHC
Impressions:
Most striking characteristic:
LCD-4 - Rich and dense tone, much more coherent sounding than LCD3-F.
HE-1000 - Air and space, more 3D, very fast and nimble. Has very comfortably replaced my SR-009 due to better tonal balance.
Presentation:
LCD-4 - dark and laid back
HE-1000 - light/airy and laid back
Treble: HE-1000 > LCD-4
Treble with HE-1000 more extended, more ethereal and better layered, enthralling sense of air.
LCD-4 much improved over LCD-3F but still not in the same league as HE-1000.
Midrange: LCD-4 > HE-1000
Nobody does midrange better than Audeze. Rich and lush. Vocals are to die for. This is where the magic happens for this headphone. HE-1000 also very good, just not LCD-4 good.
Bass: LCD-4 = HE-1000
LCD-4 is like a 12 inch subwoofer and the HE-1000 is like a 10 inch subwoofer. LCD-4 has more heft and presence especially in the midbass while HE-1000 provides more definition and finesse. Both extend satisfyingly low. Bass on HE-1000 doesn't show up unless driven by authoritative amp but with right amp, bass is no less satisfying. LCD-4 seems less picky, maybe because of larger magnet and higher sensitivity. Bass on HE-1000 better for classical, bass on LCD-4 better for rock.
Transparency: HE-1000 > LCD-4
LCD-4 much improved compared to previous LCDs but HE-1000 still more transparent. Neither are as transparent as SR-009.
Energy: LCD-4 > HE-1000
LCD-4 with more forward presence although not at Abyss level. HE-1000 seems thinner in comparison but certainly not lackluster when driven by amp with authority.
Fatiguability: HE-1000 = LCD-4
Despite more forward presence, LCD-4 easy to listen to. No annoying frequency issues noticeable so far.
Comfort (Physical): HE-1000 > LCD-4
The LCD-4 is noticeably heavier and with less comfortable clamping pressure. I prefer the softer pads on the HE-1000.
Physical Appearance and fit/finish: LCD-4 >> HE-1000
Time will tell how well the LCD-4 holds up but it seems well built. I am on my second pair of HE-1000s due to manufacturing issue with headstrap although experience with customer service was excellent. LCD-4 is the most beautiful headphone I've ever seen. Cocobolo wood is exquisite, chrome grill very tasteful and all contrast well with carbon fiber head strap. This one's the belle of the ball.
Best for:
I prefer LCD-4 for pop/rock/EDM and HE-1000 for classical/jazz. For vocals, I could be happy with either. Vocals on LCD-4 are richer while on HE-1000, vocals are better textured and more nuanced. LCD-4 may be a better for for big tubes (300B) while HE-1000 may pair better with smaller tubes (45s, 2A3s) but certainly not mutually exclusive.
In Summary:
Both are worthy of flagship status for their respective manufacturers. Both are well executed designs and both excel in producing an enjoyable and engaging listening experience for hours on end. HE-1000 seems more picky about amp to sound its best but both deserve amps that put out plenty of current. Both scale very well with the equipment you place before them. At this level, as with most things, it comes down to personal preference. The two complement each other well.
It looks like I have an LCD-4 driver failure guys
This is disconcerting, and very discouraging to prospective LCD-4 buyers....
I thought Audeze traced the LCD-3 failures to some defective films previous and has since changed suppliers, meaning the new LCD-4s should be free of this plight...
Do you know what page this quote is about the LCD4 failure? I can't find it.
Can you explain what happened? One side just go, or both?It looks like I have an LCD-4 driver failure guys:confused_face:
