Audeze LCD-2C Classic - Impressions Thread
post-15059966
Post #5,206 of 5,548
jambaj0e
Los Angeles
Los Angeles
Website
www.fotosiamo.com
They are very different sounding, completely different type of headphones. You can't really A/B compare a closed back dynamic can and an opened back planar...
First of all Mojo is a brilliant device, but not really enough to drive the 2C adequately. You won't get the bass performance it is capable of from a full sized amp.
The X00 is a fun sounding headphone with elevated and punchy bass and elevated treble. Recessed mids and a very forward, almost aggressive sound and a slightly cramped soundstage. It easily strikes inexperienced ears as the more exciting sound at first.
The 2C is a more mature sound that needs proper amplification. It sounds airy, neutral, natural and balanced in comparison. Also relaxed compared to the X00. With proper amping and enough time to adjust to the sound you will discover that the bass is more accurate and better balanced. The mids come alive but the treble is bit rolled off. I couldn't listen to X00's sharp treble.
Ultimately it is personal taste, perhaps you are not at a point in your journey yet where you can fully appreciate an opened planar sound.
These two headphones however are very different too. The 2C is technically on a much higher level but you need an amp with it.
What amp do you recommend that I can pair with the Mojo that's under $300?
post-15059976
Post #5,207 of 5,548
betula
U.K.
U.K.
I don't really know amps from that price range. Perhaps the budget line of Schiit?
Others might be able to suggest something.
post-15060021
Post #5,208 of 5,548
xRaptorxPunisher
Isle Of Wight
Isle Of Wight
Mojo is compressed sounding, not a good match for the 2C as it doesn’t have a lot of balls to put it straight; poor impact. The 2C benefits from an amp that has a lot of impact, think Lyr 2, Moj 2, Jot to name a few. The Fostex is a dynamic so more mid bass bloom so the bass will sound more overpowering. The Classic has a more textured, extended and clean bass. Listen to songs that have a lot of deep bass like Daft punks doing it right. You’ll notice the heft and sustain compared to the Fostex. Listen to the bass control on the Audeze, the pitch differentiation. A well driven 2C is a monster, they don’t scale well IMO but pairing matters.
Heck grab yourself a cheap Magni 3 and you’ll notice a difference. Ditch the Mojo grab an SDAC.
post-15060078
Post #5,209 of 5,548
endlesswaves
Singapore
Singapore
You can try a Massdrop LCX + SDAC. It's $350 but you get a nice DAC. Using it now with LCD2C and IMHO beats anything else in the same price range.
post-15060083
Post #5,210 of 5,548
jambaj0e
Los Angeles
Los Angeles
Website
www.fotosiamo.com
What about the Chord MOJO + Burson Fun with either V6 Classics or Vivid Opamp?
post-15061639
Post #5,211 of 5,548
gargani
Canada
Canada
I have a schiit magni3, a monoprice(cavalli) liguid spark,and an objective 2. They all work quite well with the lcd2c.
Keep in mind though, no matter which amp you use, you're not going to get the same bass as you're getting with your closed back dynamic headphone.The same goes for the treble.
The lcd2c is a different type of headphone with a completely different sound signature than you're used to.
post-15061663
Post #5,212 of 5,548
jambaj0e
Los Angeles
Los Angeles
Website
www.fotosiamo.com
Yeah, you're right. I was at Schitt Audio today, and unless I added the Loki, which is a hardware equalizer that allows me to pump up the bass and mid-bass, I can't get the kind of hard thump that I had w/ my Fostex, even on higher end Schitt amps:
https://www.schiit.com/products/loki
post-15061767
Post #5,213 of 5,548
bassb
Rotterdam
Rotterdam
I run a LCD2C off of an Cavalli Liquid Carbon 2.. Fantastic combination! (together with a Mytek Brooklyn DAC)..
post-15062587
Post #5,214 of 5,548
Oregonian
Oregon
Oregon
Age
58
A vintage speaker amp does these justice..................I run mine out of the speaker taps of a low power Pioneer SA-608 and it is excellent
post-15064770
Post #5,215 of 5,548
Martinoslice
Hi Oregonian, I’m using a similar setup as yourself running from the speaker taps from a paramount Zamp V2, are you using a resistor type box from the taps or are you using special cables coming straight from the speaker taps.
Cheers Marty.
post-15065063
Post #5,216 of 5,548
snellemin
Cheers Marty.
I run mine from a pair of Parasound V3 speaker tabs. No resistor box needed.
post-15065684
Post #5,217 of 5,548
Oregonian
Oregon
Oregon
Age
58
Cheers Marty.
Straight out of the taps, no resistor box. Just start with the volume all the way off when powering up and go up from there.
post-15065762
Post #5,218 of 5,548
Martinoslice
Oh Really, good to know as I’ve been using a resistor box, did you get the cables especially made with bananas or are you using some sort of adapter.
Cheers Marty.
post-15067421
Post #5,219 of 5,548
Oregonian
Oregon
Oregon
Age
58
Cheers Marty.
Had a cable made by Ted@Headphone Lounge that has tinned speaker tap connector wires to XLR.................
Reactions: Martinoslice
Users Who Are Viewing This Thread (Users: 0, Guests: 3)
