I guess I need 2 answer this question about Ed.8 vs LCD 2 cuz they are the last two cans I am gonna keep. So for me I can't say which one is better cuz they got equal amount of usage.
Transparency: they are pretty much equal. I would say Ed.8 has a lil bit more.
Bass: They both really really good at doing bass. Two best bass headphones I ever heard. Ed.8's bass is fast, tighter and also really really punchy. LCD 2 's bass is deep, more impact, and more bass weight. U wont go wrong with either.
Mids: I dun need 2 say more here. LCD 2 got the mids to die for. Ed.8 not bad.
Highs/treble: Ed.8 is more bright than LCD 2 obviously. LCD 2 sounds warm or "dark" if you wanna say, although I personally dun find it any recessed. I find it perfect since I fear sibilance. Ed.8 's high/treble sounds really standard, neither bright nor dark.
Soundstage: I cant compare here. no comparison since they are different types of cans.
Comfort: Ed. 8 clamps a lil tight as first, but still it's so light, so it's more comfortable than LCD 2. LCD 2 I found it comfortable too, the weight is really well distributed. But still u might wanna consider the weight issue.
Also Ed.8 is portable, LCD 2 is not.
I love Ed.8. But if I hv to keep one, I would prefer LCD 2. according from you genres u won't go wrong with either. if you dun do mixing, LCD 2 is probably ur first choice. If you want a lil bit neutral sound, Ed.8 or T1 (which I found it lack of bass and bright) should be considered.
Hey guys,
I am thinking about getting an LCD2, but my source makes me reluctant to buy. So first off, I am an amateur audiophile. I plan on using this as my open ended can on my desktop. My current desktop rig has an Asus Xonar ST w/ the dedicated amp. I am kind of a bass head, but I won't sacrifice the rest of the spectrum. I'd say 80% of my music is pop, rap, rock and on those genre's I am a fan of bass boost. I also plan on using these cans for internet media, movies, and games. Naturally, all of this media has a pretty broad range of bitrates. Now I would like to know if anyone has experience or audiophile insight into this kind of a set up. Would these cans still kick ass w/ that DAC amp combo? What about if I used a better amp, but still used the DAC? Or does the entire set up gotta go?
Also, I am curious if anyone has any insight comparing Ultrasone Edition 8s with LCD2s. Btw I know its not fair to compare closed vs open, but its all I really have to compare.
Thanks!
