I'm a little worried with LCD-2 'potential' (cause I don't have yet) clamping. We will be able to bend the headband or metal or something little like HD650 so it won't clamp so much?
As someone who eventually let go of the HD650 partly due to their unbearable clamp, I can say that I can deal with LCD-2's clamp fine. As it's been said, it's not neither too clampy or too loose.
I must say if you let go of the 650s for that reason, you let go of them too soon. The 650s take about two weeks to loosen up and then, unless you're a total balloon head, they become one of the most comfortable phones ever manufactured. Or...you can just bend the metal. I fail to understand why this is such an issue with so many people (and I won't get into the subject of a certain amount of clamping force being necessary to maintain bass response).
There's a few reasons at work here from my perspective (which I should have mentioned earlier, to be fair):
- I owned the HD650's for a year or so, and they never really loosened up enough to be comfortable for me. Trust me, I gave it plenty of time.
- Bending the metal, from my experience, was a
temporary solution, not a permanent one. The metal headband actually has strong memory and always bends back in its original shape after a few days. Didn't like having to do that once every few days.
- The leather pads of the LCD-2 seemed to give me more "give" and less pressure that the HD650 velours put on side of my face. For the same reason, I actually prefer the pleather pads of HD25 over velour... most velour pads seem a little too hard for my liking.
- I actually do have a larger head than average, I think.
- This is more of a personal reason, but I do have problems with headphones that have oval-shaped cups in general, due to me having a minor case of TMJ. Those type of pads unfortunately line along my jaw line, making it painful.
- LCD-2's pads have wider contact surface, which seemed to distribute the pressure more evenly.
