Audeze iSINE 10 & iSINE 20: Audeze releases two new IEM planar magnetic earphones
423 424 425 426 427 428 429 430 431 432
434 435 436 437 438 439 440 441 442 443
  1. Maximiliano Campo
    Can anyone tell me if this would work from an Astell and Kern player through USB-C port? Would it power the cipher cable this way?
  2. harpo1
    @KMann mentioned awhile back they were going to get one and test it out with android. Hopefully he can chime in and gives us some insight.
  3. greenkiwi
    There were a couple updates saying it worked with google android phones, but that the playback buttons might have stopped working after a day or two.
  4. strawberry
    Screenshot_20190605_083344_com.amazon.mShop.android.shopping.jpg Hello I am a newcomer
    I had the isine20 for 2 months. I like its transperancy.
    However there is problems with ear fitting
    I read this post someone has tried to fit the jaybird bluebuds earfins onto isine? Does this work? I tried to search this forum but no answer. Appreciate any advice.
  5. Vitandus
    Hnnnggggg.... Listening to my new @FiiO M11 with the iSine 20 on Cipher Cable to the Anker Lightning/USBC adapter. The iSine 20 seems to work better this way than using the M11's EQ. Oh yeah, this is good. Really good.
    AlwaysForward and trellus like this.
  6. harpo1
    So @KMann since the Anker adapter appears to work with Android will you guys develop an app like you have for IOS?
  7. gemNeye
    According to @chungoooo the Anker adapter works with a Shanling M1 dap. So it's quite possible it should work with other USB-C capable daps, I would assume?
    See links below.
    https://www.head-fi.org/threads/lig...er-lightning-headphones.908190/#post-14990010
    https://www.head-fi.org/threads/ank...ines-with-lightning-dac.907473/#post-14985427
  8. chungoooo
    Yeap, i tested with my shanling and works, and volume and pause buttons works without any configuration, in fact i was surprised by that :), just plug and listen
    acia and gemNeye like this.
  9. Redhell08
    real question is if this adapter works why is there no official cipher android version, i bet it would sell...
  10. acia
    Won’t work for sure for me.
  11. showme99
    I'm hoping that this product will cause Audeze to re-think its stance on developing a USB-C cipher cable. Fingers crossed.
  12. Vitandus
    Im really torn between the Cipher Cable and EQ. The former seems to offer a little more depth? detail? something to the music. Anyone else try both?
  13. Tristy
    Just tried it with my SP1000M and it doesn't play music... strangely I am still able to turn up the volume and play / pause. Bizarre.
    Works great with the MacBook though!
    trellus likes this.
  14. strawberry
  15. acia
    Not much point if ldac can handle 24 96.
