Ad-Astra
How do you compare this to anedio d2?
[...] Also the Deckard has many different parts including a differend PSU so it might sound very different (depending on the personal grade of audio nervosa) than the Matrix. [...] .
Spec shows Line-out as Class-A. Is the headphone amp section also Class-A ?
What are the usual prices you guys have seen for this amp when Refurbished from Audeze?
I’ve heard others say they grabbed some recently from Audeze (Amazon) for $340. Is a Refurbished unit worth $500 or so?
Thanks everyone! I’m going to take the weekend and decide if I want to pull the trigger.
Follow-up question about the amp — the website says it is Class A, but A-Weighted. Does that mean this is not a full 100% Class A amp but only weighted towards A, but could switch to B at some point?
There's a hole in the side of the volume knob with a set screw in it. It's probably just loose. Find the right allen wrench to tighten it.So I managed to grab a Refurbished Deckard from the Audeze Headphone Amazon page and it arrived today. Everything was accounted for (save for the USB cable, which is fine since I have my own), but as soon as I removed it from the packaging the Deckard's volume knob just fell right off.
Doesn't look like it is something where I can snap it back into place. I emailed Audeze and waiting to hear back. Otherwise, is my only option to use glue? I'm not very handy. Anyone have any ideas? Bummer!
