ScubadudeSA
- Aug 28, 2015
Quoting myself from another forum ... seems to fit in here quite nicely ...
After previously posting some less than flattering comments about the Audeze Deckard on this and other forums I picked up a lightly used unit. I have now spent some serious time with this DAC/amp and am a changed man. This is a $700 amp that gives my usual $3500 SPL / Wadia rig a very good run. Not better I would say but certainly not significantly worse. Even if the Deckard is a molested Matrix M-Stage under that sleek BMW Designworks styled exterior, I now rate this as one of the best values in head-fi .... authority and finesse, clarity and warmth, and a wonderfully involving presentation of the sound stage. Mega bang for buck here!
OK, so I did a bit of reading on the similarities (and more importantly differences) between the Deckard and the Matrix M-Stage HPA-3U. Pics of the innards of the two amps can be found here ... http://www.head-fi.org/t/749486/audeze-deckard-class-a-amp-usb-dac/120#post_11872066 and http://www.head-fi.org/products/matrix-m-stage/reviews/13475
Clearly a lot of shared design and components here, but not identical. In all cases Deckard first, M-Stage second:
- DAC Chip: TI Burr Brown PCM5102A vs TI DSD1793
- DAC Resolution: 32/384 (no DSD) vs 24/192 and DSD64
- Power Supply: Uprated vs standard
- Component Mounting: Through-board vs surface mount
- Component Selection: Different output stage caps
- Buffer Stage: Discreet "diamond buffer" vs integrated circuit
- Exterior Industrial Design: BMW Designworks vs Chinese utilitarian
- Output Impedance: 3 ohm vs 0.4 ohm
- Power Output: 4W at 20 ohms, 795mW at 33ohms, 465mW at 300ohms, 235mW at 600ohms vs 2800mW at 33ohms / 420mW at 300ohms / 210mW at 600ohms at THD+N=0.01%
- Mass: 2.1 kg / 4.6 lbs vs 1.7 kg / 3.75 lbs
- Price: US$699 vs US$419
So definately not identical twins these! I have not heard the M-Stage but after spending some quality time with the Deckard I am quite smitten!
