scope1992
- Jul 2, 2013
Apparently they look like this:
I ordered a similar looking one call philmore something. Hopefully it will be the same quality. The one you showed seems to be more compact and the padding might not need to be removing to insert it.
Personally, I glued on the inside, looks fine from the outside. Although, I'm not too sure which chassis the Lumberg is exactly (google images spits out a few different results).
I used these:
