meizumintyboi
- Jun 2, 2007
I was finding the dangling jack annoying after a while, so I removed the rubber tubing with tweezers, then filed down the hold with a curved file, put some black electrical tape around the jack to ensure the plug fitted tightly, and pushed it up as far as it would go.
If you do try this make sure you don't make the hole too big, but I am definitely prefer this to the plug just hanging out, to do this you will also have to remove one of the plastic pieces with pliers.
