diver110
- Jun 10, 2015
You need a micro usb OTG cable. I followed Jason’s instructions and mine worked just as he said connecting to a Mojo.
Skeptical, but it was cheap, so I ordered one.
There was an update this week that contained bug fixes and OS optimizations.
To update, turn on WiFi. Make sure you are connected to the internet. A message should pop up alerting you to a software update. If one does not, go to settings, update, click on system update and it should prompt you to download and install the update.
Skeptical? Every DAP I have used to connect to an external DAC via USB required the use of an OTG cable. Astell & Kern notes this in the SR15 information on their website with pictures of how to connect it (https://www.astellnkern.com/eng/con...scg=CG232020&spos=2&tcg=&tpos=0&gcode=SC32080):
USB Audio
A simple USB connection will allow the A&norma SR15 to be used as a digital music storage device and
/or pre-amp to output digital audio through USB.
The A&norma SR15 transfers DSD in native format through DoP (DSD over PCM) and converts DSD to PCM for output
for external USB Audio that do not support DoP.
* USB audio (Digital Out) output is available only when an external device can accept digital input through USB.
* DoP (DSD over PCM): This is the standard for transferring DSD data to a USB interface and sends DSD data by mounting them onto PCM data frames.
* The type of OTG cable to connect the SR15 with a portable amp differs depending on the specs of the amp. An OTG cable is not included in the SR15 package.
For the record, I certainly appreciate the feedback. The reason I am skeptical is that I have had two sets of cables in play, and it still did not work. One was, I believe, an OTG cable that came with the Hugo. Interestingly, the male plug would not fully go into the female. The people at the Grammaphone store said it was going in far enough, but perhaps there were mistaken. I will find out soon.
Since the Hugo 2 comes with an OTG cable, another thing I have learned is that the OTG end of the cable needs to be connected to the DAP (SR15), but I have never seen a cable that identified which is the OTG end, so, if I have a problem with it not connecting the first thing I try is to reverse the cable. Always worth a try. As far as the male plug not fully going into the the female, that is a common condition because the connectors are not very standard size wise. Insertion is most likely not the problem.
OTG = On the GoIt is possible that I did not try reversing it, though at that point I still had old firmware on the AK, so perhaps it still would not have worked. I will watch for that when I get the new cable. What does OTG stand for?
Sorry, what version software is the SR15 running? There was a bug in an earlier version regarding USB output that was fixed. The current firmware version of the SR15 is 1.11. You can check the firmware version by going to settings, System information. Second line is Firmware version.
The back button can be dragged around the screen and placed somewhere else.Speaking about ver 1.1 I hate the way the ‘back’ button is so close to the ‘next’ button on the now playing screen. It’s too close and that circle spoils the symmetry.
Could you maybe put an idea forward of making it just a small arrow (no circle) and move it to the upper left of the screen- or somewhere else it’s not as obtrusive.
Other than that, this is easily the best ‘small’ dap that you can buy and still have top tier sound. And it looks totally tubular, well angular ha ha. It’s a real stunner.
TY.
Stay updated on Astell&Kern at their sponsor profile on Head-Fi.
I'm hoping A&K settle their supplier issues with Canada so my local audio shop can re-stock and order my SR15 im so impatient.
Lol well colour me simple. That’s great news, I still think a small arrow would be nicer but hey moving it is a great feature. I’ll have to explore the menu more, just recieved it yesterday.
Thanks for the quick response. I’m listening to Jeff Kashiwa ‘Another Door Opens’ right now using my AK T8iE and it sounds dreamy. Haven’t even tried balanced yet.
