Audiophonicalistic
Which iem or headphone you pairing it with?
I received my SE100 this afternoon. Took it out of the box and immediately fitted the screen protector and put the SD card from my XDP into the SE100. Booted up and updated the software. Loaded Spotify and got some playlists downloaded.
For the last hour I have been listening to a mix of Queen, Japan, George Michael, Mark Knopfler, Eminem, Jean Micheal Jarre through FLAC files and some Spotify.
I'm struggling to find words to describe the sound through my SE535's. I had to tweak the EQ a little to roll of a little high end but other than that the sound from the SE100 is very very well balanced to my ears, also noise I used to hear is no longer there which shames the Pioneer I have been using.
For the minute I am thoroughly impressed with the SE100.
You are right. Just EQi just want to make sure that se100 has no low or high gain setting, am I right?
No. The Ultimate Series does support APKs I think. The reason I favored Neutron was because of the parametric EQ, which the SE100 has natively.i was wondering would installing third party players like neutron work with sideloading
are saying the shures are not a good match? i use jupiter campfire on balanced and its just great.. thinking of getting Andromeda's as i have heard ( no pun intended) that they are better match for the se100this great dap deserve a better iem than u have
Would you care to expand on your statement? Should I go out and buy a pair of SE846's or maybe a pair you recommend?
well shure 846 is good, but still SE100 deserves a way better iem.
But I am not here to rec iems that are crazy priced, but check out some from empire ears but watch your wallet
