lawshredpower
Oh, I was talking about Roon.Cube was announced yesterday!
my apologies, I thought you were talking about TidalOh, I was talking about Roon.
I posted about this on the previous page of this thread (Post #1,345). There will be a firmware update next week adding Roon Ready support to the KANN ALPHA. The software team was waiting for all the Tidal firmware fixes to go out first and confirm there were no issues with the update before pushing out another update to enable Roon Ready.AK website is showing Kann Alpha to be Roon Ready, but I have not seen any FW update for that.... maybe an imminent release @JasonNYC ?
Stay updated on Astell&Kern at their sponsor profile on Head-Fi.
The morning of June 21 Korea time is the tentative release date.@JasonNYC I know you did, you replied to me actually.
However, seeing that mentioned on the AK website made me wonder if the FW was out there already.... or just imminent.
At this moment, the advertising on the website is just misleading, the Roon icon should not be there if the Kann Alpha is not ready yet.
...following my June 7 post regarding Tidal embedded app crashing in login after 1.14 update, there will be some kind of fix? Have other users experienced the same problem?I posted about this on the previous page of this thread (Post #1,345). There will be a firmware update next week adding Roon Ready support to the KANN ALPHA. The software team was waiting for all the Tidal firmware fixes to go out first and confirm there were no issues with the update before pushing out another update to enable Roon Ready.
There were problems with the built-in tidal, could not enter. I installed tidal 2.34.1 before the 1.14 update and did not return to the built-in anymore. tidal is working , I have no problems with losing wifi....following my June 7 post regarding Tidal embedded app crashing in login after 1.14 update, there will be some kind of fix? Have other users experienced the same problem?
I apologize, I thought I had responded back....following my June 7 post regarding Tidal embedded app crashing in login after 1.14 update, there will be some kind of fix? Have other users experienced the same problem?
Hello Jason, how about the problems that I described to you, the developers to fix? I’m talking about sleep patterns, I’m worried about that the most.I apologize, I thought I had responded back.
We have no reports of crashing of the embedded app after the 1.14 update. I have asked both our North America support team and our global support team. Our global support team was inquiring with other regions to see if there were any reported issues.
The next KANN APLHA firmware update is expected the morning of June 21st in Korea (late night Sunday, 6/20 in North America/ middle of the night 6/21 in Europe). In addition to adding Roon Ready support, there are a number of bug fixes included in the update.
As the soft reset did not fix the issue, I would suggest waiting for the next firmware update next week or try a factory reset. A factory reset will erase all files and settings on your player, so you may want to try the next firmware update in a few days.
I never used the embedded Tidal app as it doesn't support for known reasons offline playback. I do use too the sideloaded app without any problems whatsoever. I was simply curious why the embedded app stopped working after the update which was supposed to fix the login problems...There were problems with the built-in tidal, could not enter. I installed tidal 2.34.1 before the 1.14 update and did not return to the built-in anymore. tidal is working , I have no problems with losing wifi.
