Astell&Kern Launches KANN ALPHA Digital Audio Player
Jun 21, 2021 at 1:22 AM Post #1,381 of 2,136
FYI: FW update OTA just came on. :)
Jun 21, 2021 at 1:45 AM Post #1,382 of 2,136
There you go! Works nicely
Jun 21, 2021 at 3:35 AM Post #1,383 of 2,136
Ive Updated my Alpha, it shows in the settings as Roon Ready, but that's as far as I get.
How do I get it to work? Please?
If I go into Roon on my Laptop, it doesn't see the Alpha. I have Roon running on a NUC, with Roon Rock. It works fine with my Bluesound Node 2i, and with my iPad, iPhone etc.
I've been waiting forever for Roon for my Kann Alpha, and now I can't get it to work.
Any help/instructions gratefully received. Thank you.
Jun 21, 2021 at 4:18 AM Post #1,384 of 2,136
hi @Scubacrazy
Silly question... have you enabled the Alpha in Roon's settings ? Roon>Settings>Audio>Roon Ready devices>Kann Alpha>Enable
Also, I guess Roon should be running on the Alpha to make it work
I am not at home these days, but I am looking forward to try Roon on my alpha once I am back next Wednesday
Jun 21, 2021 at 5:16 AM Post #1,386 of 2,136
Is wifi turned off maybe?
Jun 21, 2021 at 5:40 AM Post #1,388 of 2,136
hi @Scubacrazy
Alpha isn't even listed in Roon ready section of /settings/audio.
I'm about to reboot everything, and see if that helps.
Thanks for your reply. I'll report back shortly.
Jun 21, 2021 at 11:18 AM Post #1,392 of 2,136
Hey Kiats, could you please clarify if you are playing this from the roon app on the KA or streaming to the KA using roon as a control app on another device. I want to be able to play on the KA from the roon app installed on the KA. If at all this is possible. Thanks.
Jun 21, 2021 at 11:20 AM Post #1,393 of 2,136
Using Roon app on another device. As a Roon Ready endpoint, you cannot use the player to control Roon.
Astell&Kern Stay updated on Astell&Kern at their sponsor profile on Head-Fi.
https://www.facebook.com/astellnkern/ https://twitter.com/astell_kern https://www.instagram.com/astellnkern.official/ https://astellnkern.com astellnkern@astellnkern.com
Jun 21, 2021 at 11:34 AM Post #1,394 of 2,136
@JasonNYC has replied. Agree with him. When I tried doing it with DX300, what happens is it goes through android resampling. AK's way means you skip the android limitations
Jun 21, 2021 at 11:47 AM Post #1,395 of 2,136
I have some 60-day trial codes for Roon if anyone is interested in trying it out. The standard demo period if you sign up from Roon is 30 days. Unfortunately I cannot walk anyone through on how to install Roon Core and get it up and running on their network, but it is pretty easy if you want to install on a Windows or Mac computer to test. Please PM me if you would like a trial code. They are unique codes, so I will have to send individually to anyone that is interested.
