No offline mode.
What's the point of providing tidal in a portable DAP without offline. In this day and age streaming with offline is a mandatory feature.
No offline mode.
http://shop2.dignis.cafe24.com/product/mercury-ak-kann-case/161/?cate_no=85&display_group=1
Purty, please report on quality!
Went to the website and feels like a complicated International order. How long do you think it will be until this case is offered through Amazon?
I had the same problem. When i listen to music from the memory, the sleep timer works fine. But if Tidal is running, it doesnt. So i guess this is a temporary os bug.Hi - my Kann does not switch the player off when the sleep timer expires. The screen turns off and the music stops but that's all. Set it for 30 mins last night and this morning the battery was down from 100% to 40% and the last played track was flashing on pause
Anyone else had this experience?
I do have a problem with the KANN. It does not read or show my Kingston 512GB SD Card. The funny thing is, that if i use it with an Micro-SD Adapter in the MicroSD Slot, it works fine and shows all the files. Does anyone know how to fix this? Being able to use my 512GB SD Card without adapters was the main reason to get the KANN.
