olddude
I have had problems with AFT. I found that you really have to use the cable that comes with the AK.
You should always use the AK USB cable for Data transfers. I have a different cable for charging.
If you listen by your heart, without any prejudice of what you currently own, you will find that AK380Cu is the true gem among all DAPs. Simply the best. The advance from AK380 to AK380Cu is far far greater than from AK240 over AK380. Try to do a blind test if you don't believe. You'll be amazed.
Indeed. As I mentioned in an earlier post, my ripper won't work consistently unless I use the cable that came with it to connect to my 380. Using the original cable it works 100% of the time.
Has anyone purchased the 380SS? I'm interested in how much better it sounds over a stock 380, or the 380cu.
I'm guessing that it will be 'brighter' with a more 'reflective' 'shinier' sense to the music.
