Astell&Kern AK380
post-13346277
Post #8,191 of 8,903
Uncle Monty
UK
UK
I had problems using AFT to transfer files from internal memory to SD card - assumed it was AFT issue. I laid my problems bare a couple of weeks ago on this forum. If the issue is with AK, they should get it sorted - I'll bet a great many AK owners use Macs. Thinking of getting a windows laptop for future file movement (it would be useful for some other things - I wouldn't buy one just for this).
post-13350163
Post #8,192 of 8,903
bflat
San Francisco
San Francisco
Trying out my CU stack with Oriolus Forsteni, I get slight different sounds with and without amp:
No amp - straight from the AK380 CU, the mids have a little more weight and highs are a little laid back
Thru amp - little tighter bass, mids a little leaner, highs more sparkle and edge
Both are balanced out.
I think I prefer no amp with the Forsteni which is cool since I got these for pure travel purposes. However, with my Laylas it's thru amp or nothing. Just an amazing combo.
Why the Forsteni? It suits my listening tastes and happen to fit flush in my ears like a custom. I use sound proof ear muffs (normally used at gun ranges) to slip over my ears with the Forsteni inserted. I estimate this creates -50 dB or more sound deadening which is awesome given the 80+ dB noise on planes. Obviously this is impossible with the Laylas!
post-13355157
Post #8,193 of 8,903
Eroica4th
Banned: Multiple incomplete trades. Previously known as Exhuman93
For so many times, whenever i lock the dap and hold it in my hand i sometimes get surprised that it is either playing the next song or into random folder, that is the screen didn't switch off ( locked off ) i always says duh i pressed the lock button twice mistakenly or it is way sensitive. However, today i discovered that if the screen is on and you press the lock button while you are touching the screen, the screen will automatically switch off then on... as far as i remember i have not read something related in the user manual. Which is quite odd!!! If someone experience the same thing please aware me:D
Hope this helps.
post-13355189
Post #8,194 of 8,903
Eroica4th
one more odd thing. This time it happened with my ak240ss as well as my ak380cu.
sometime whenever i remove the SE cable from the dap i see red light coming from the SE port. which is again veryyyyy odd, especially that none mentioned it :O
post-13355211
Post #8,195 of 8,903
Dellwolf
Lincolnton, North Carolina
That's because it also functions as an optical output.
post-13355235
Post #8,196 of 8,903
Eroica4th
i cant find any option in the dap that would make it play optical output :frowning2:
post-13355240
Post #8,197 of 8,903
Eroica4th
using se846 and ie80 SE cables
post-13356668
Post #8,198 of 8,903
LouisArmstrong
Nice. Really nice.
post-13359395
Post #8,199 of 8,903
Bengkia369
There is no need for any option, it's basically plug and play. The AK will just optical out if you plug a optical cable to a external DAC.
post-13366825
Post #8,200 of 8,903
bflat
San Francisco
San Francisco
If you want to believe how "small" the AK380 is, just use the AK Amp for about 3 months and then go back to just the AK380. It will seem tiny and so light!
post-13367639
Post #8,201 of 8,903
TaylorDawe
*laughs* yes, that is exactly what I did! I actually love the look and feel of the 380 alone and haven't used the amp since taking it off.
post-13367690
Post #8,202 of 8,903
catalystcc
It would be nice for the upcoming AK flagship to have a swappable amp instead of an add on.
post-13367787
Post #8,203 of 8,903
raypin
San Fransokyo
San Fransokyo
Mm...ssshhh! Don't give them ideas.........module 1 usd 1500.00, module 2 usd 1800.00.......bad for us!
post-13368111
Post #8,204 of 8,903
LouisArmstrong
Copper is the King.
Users Who Are Viewing This Thread (Users: 0, Guests: 3)
