- Aug 15, 2011
I've upgraded but yet to even try 1.4. Do others share STAXNBS sentiments about the SQ of 1.4?
hello what negative changes you notice?Hello I am new here. Need help. Yesterday I did the Firmware Update of my AK380 to Version 1.4 . I dont like the changes in the Sound Quality. I want to go back to Version 1.32. How can I manage this. Thank you for your support to do this.
Hi,
did anyone of you have the chance to listen to the Orilolus mk2 IEM´s out of the AK380? How do they pair? Thanks in advance!
Hello Ultrainferno Thanx for your answer. But where can I get the AK380 firmware version 1.32 Hexfile to download
Hi All,
Does anyone know what the max bitrate out from the optical output is on the ak380?
I have a 24bit 192Khz file that registers as no data when being played on the optical input of the Chord DAVE.
Cheers
I see no sense to put a new firmware.![]()
The Soundquality changes coming with firmware upgrade 1.4: The sound is mich more lighter. More hiss. Less ground and bass pressure and to my taste. it sounds flat and nervously.
Sorry it was late and I don't think I put the question very clearly :blink:
I am running the following setup:
AK380 optical output -> Chord DAVE optical input
All good until the Coldplay album that is 24bit 192Khz plays ....
The Chord Dave supports this but my question is does the AK380 support this format on it's optical output (Chord DAVE shows no data when the album is playing)?
Couldn't find anything online regarding the specs on the AK380 optical output so was wondering if anyone has any experience with this.
I don't have the AK380, but my AK240 outputs 24/192 correctly through optical to the Mojo, and I presume it would to my DAVE as well but I haven't tried it. What cable are you using? Depending on the bandwidth of the optical cable you may not be able to push the 24/192 data through. I would be surprised if it was handicapped at the player and not the cable.
