Astell&Kern A&ultima SP3000
Dec 1, 2024 at 10:41 AM Post #5,057 of 5,518
Have you looked on the Roon forum to see if this question has already been asked/answered?
First place I went. There was one query with no real solution. The roon techie figured the OP was using a vpn. Have you tried it?
Dec 1, 2024 at 7:44 PM Post #5,059 of 5,518
Not with ARC, only in the main Roon system where it is working well. I don’t use ARC so I can’t test it for you.
Even if there is not a fix it is pretty easy to make a headphone eq in desktop roon, convert to parametric, copy the setpoints and then input them in ARC as a parametric. I’m finding I prefer the EQ’s I have done with the sp3k equalizer anyway. That way they are the same for all services even ARC.
Dec 2, 2024 at 12:38 PM Post #5,062 of 5,518
I am using SP3000 USB with Hugo M Scaler then Hugo TT2 DAC. Sounded much better to my ears.
Thanks, so you do rate it as a worthy source for a TT2 then, which is exactly what I have in mind.
And do know if the resampling is applied (less relevant to you since you have an M Scaler)
And what cable do you use? Presumably it needs to be OTG, and there can't be many options for that?
Dec 2, 2024 at 1:10 PM Post #5,063 of 5,518
Yes, it is worth it for me even if you don't even use M Scaler. Some of my friends also using SP3000 and TT2 without M Scaler and they are happy with them. I am using stock USB to M Scaler, dual BNC from M Scaler to TT2 from Amazon at the moment. I will get Oyaide USB and BNC when I am in Japan in a month or two.
Dec 2, 2024 at 3:25 PM Post #5,064 of 5,518
Has anyone loaded roon arc 1.0.60 to try the new Headphone EQ option? I keep getting this….
I think it must be similar to what was experienced with the browser and login issues on Qobuz.
No issues with 1.0.60 on either the SP3000M or SP3000T. I was able to select multiple headphone profiles and no error messages. I don't have my SP3000 with me at the moment, will try it out when I can.
Maybe try deleting and reinstalling Roon Arc. I know that will erase any offline downloads that you have though.
Astell&Kern Stay updated on Astell&Kern at their sponsor profile on Head-Fi.
https://www.facebook.com/astellnkern/ https://twitter.com/astell_kern https://www.instagram.com/astellnkern.official/ https://astellnkern.com astellnkern@astellnkern.com
Dec 2, 2024 at 5:06 PM Post #5,065 of 5,518
Thanks! It must be in my network. Maybe my dns. I will try your idea on deleting it first.
Dec 5, 2024 at 8:38 AM Post #5,067 of 5,518
Dec 6, 2024 at 6:40 PM Post #5,068 of 5,518
What is PGGB? :scream:
I don´t see this funkcion in my SP3000.
Dec 6, 2024 at 7:04 PM Post #5,069 of 5,518
LOL
It upscales your music files; does the same thing (more or less) as DAR and products like the Chord Mscaler. In theory, it provides better upscaling because it doesn't do it as the music plays, so it can analyze an entire music file at once and do better upsampling.
It requires serious hardware to run though, and the files it produces can be pretty massive, especially if you upscale to 768 kHz. Yes you can configure things like the types of filters it uses and the target sample rate.
One very nice feature if you use EQ... It can apply the EQ as it upscales, so your DAP doesn't have to.
Downside is it won't work for streaming music, this is strictly a preprocessing product; and processing a large music library can take a while. Like, several days if you have hundreds of gigabytes of music.
Check it out: https://www.remastero.com/pggb.html
Dec 7, 2024 at 7:07 PM Post #5,070 of 5,518
Does DAR work on music being streamed or is it only on music you have on SD or internal memory? When I’ve tried it I don’t really hear much difference to the music.
