Astell&Kern A&ultima SP3000
Dec 8, 2024 at 1:49 PM Post #5,074 of 5,591
Yes DAR works on streaming along with the EQ.
Both also work using line out but you can’t adjust the EQ.
I tried DAR and I don´t recognize no difference.
Dec 10, 2024 at 12:16 PM Post #5,077 of 5,591
New here so go easy if I'm posting to the wrong place.
Could use a bit of help with an SP3000 I've just bought. At least nine time out of ten the screen on boot-up is completely blank but dark blue, eventually changing back to black once the thing seems to have booted. I then have to press the volume button twice again to get the display to appear correctly. Very occasionally on boot it will actually display the Astell & Kern graphic followed by the scrolling marquee of the graphic as I assume it's actually supposed to.
Anyone else had, or know anything about, this 'problem' as otherwise everything seems to be working fine. On v1.42 (latest) firmware. Factory reset makes no difference. Same thing happens with or without SD card.
Dec 10, 2024 at 5:44 PM Post #5,078 of 5,591
Welcome to Head-fi.
Seems like something’s not working right with your SP3000. I wonder in the first instance if @JasonNYC from A&K can suggest something like a hard reset or similar magic to help.
Dec 10, 2024 at 6:02 PM Post #5,079 of 5,591
Are you powering it up while it’s on charge. I’ve had this happen a couple of times but it’s always been after it’s fully charged and the cable is still connected. Doesn’t happen for me when it’s not on charge.
Dec 10, 2024 at 6:15 PM Post #5,080 of 5,591
Many thanks for your reply.
It seems to be almost all the time, whether it's on charge with the cable connected or not. I'm charging it via the USB port on a PC and it seems to charge just fine. I've tried fully charging it and it still happens. I'm now trying to fully discharge it to see what happens. A & K support have suggested that 'it is possible that there may be a fault with the memory IC or CPU' but as it's now outside their 30 day warranty want to charge me to 'repair' it. I'm a software engineer and it sounds far more like a software issue to me.
Dec 10, 2024 at 6:30 PM Post #5,081 of 5,591
I'm not sure what the issue may be and havent seen this issue reported with the SP3000. I will follow up with the software team when they are in the office.
There is a one year warranty on all of our products, so if it is an issue covered under warranty, there would be no charge. I assume the 30 days you are referring to is a return/exchange from the place of purchase.
Astell&Kern Stay updated on Astell&Kern at their sponsor profile on Head-Fi.
https://www.facebook.com/astellnkern/ https://twitter.com/astell_kern https://www.instagram.com/astellnkern.official/ https://astellnkern.com astellnkern@astellnkern.com
Dec 10, 2024 at 6:35 PM Post #5,082 of 5,591
Also once it starts, any issue with playback or is the issue only on the boot up screen? Any other issues once the player starts?
Dec 11, 2024 at 5:38 AM Post #5,083 of 5,591
Thank you for your input and the warranty info. The confusion over the 30 days was this sentence in a message from your CS:
'If you recently purchased the device, you may be eligible for a refund or exchange through the retailer within 30 days of purchase ' but re-reading it now this may relate to any retailer warranty. However, at no point did CS indicate that there was actually a 1 year warranty on the device. Does this warranty go with the device, or is it only available to the original purchaser?
As far as I can tell, the issue is only with the boot-up screen. Almost everything else seems absolutely fine. The only other issue I've noticed is that on shutdown, sometimes the battery level indicator is displayed but at other times it isn't.
Dec 11, 2024 at 10:04 AM Post #5,084 of 5,591
I apologize for any confusion from customer service. The warranty period is one year from date of purchase and is valid for the original owner and only when purchased from an authorized Astell&Kern dealer. For those located in the EU, warranty period is two years due to EU regulations. Unfortunately, since the UK is no longer part of the EU, warranty period for devices purchased in the UK is only one year.
There is a warranty card in the box which also has this information.
I have the software team looking into the issue and hopefully should receive a response in the next day or two. They acknowledged receipt of the issue and told me they are checking it out.
Dec 12, 2024 at 1:31 AM Post #5,085 of 5,591
hi, I am looking to upgrade from a dx320 using a 2tb card.
i value streaming apps and their download for offline is my only source + streaming.
are the tidal, qobuz, apple music apps as snappy on the sp3000 & sp3000m just as snappy as on the dx320?
i can’t find any direct comparison reviews between the sp3000 & sp3000m.
i am using a12t’s. i am open to either of the sp3000 or sp3000m. which is better?
