Luke Skywalker
Hey guys, I'm looking for some kind of USB-C splitter that would allow me to use my SP 3000 in digital output mode while charging it at the same time. Can anyone recommend one? Thanks!
I’ve tried extensively several high end daps. The dx300 and 320 (non max) don’t even get closer to the sp3k in terms of sound quality.I planed to upgrade my SP1000 to a SP3000 but... I wonder if the iBaso DX320MAX Ti or the Lotoo Mjolnir will not sound better (price and size is not an issue. Only sound...). Any one compared them ?
FWIW, I sold my SP3K Cu in favour of the DX320 Max Ti. I love SP3K's SQ, but I feel the 320 Max takes it up a notch. The obvious trade off is portability, but for my use case (which is strictly at-home listening with DAPs) I can live with the bigger footprint.I planed to upgrade my SP1000 to a SP3000 but... I wonder if the iBaso DX320MAX Ti or the Lotoo Mjolnir will not sound better (price and size is not an issue. Only sound...). Any one compared them ?
Yes, I connect a SSD 2TB and it reads fast and plays perfectly. It's a pleasant surprise. My SP 3000 suddenly has a heck of a lot more storage. It's not completely portable this way of course, but at my desk it's a game changer.Is it possible to connect a portable ssd to the SP3000. via an otg cable?
it works in folder mode ?Yes, I connect a SSD 2TB and it reads fast and plays perfectly. It's a pleasant surprise. My SP 3000 suddenly has a heck of a lot more storage. It's not completely portable this way of course, but at my desk it's a game changer.
I have A&K 380 and LPGT TII planed to upgrade my SP1000 to a SP3000 but... I wonder if the iBaso DX320MAX Ti or the Lotoo Mjolnir will not sound better (price and size is not an issue. Only sound...). Any one compared them ?
Molnjir is another level.Much better than sp 3000 and better in every parameter than LPGT TI
Is in another league.Price around 7.000 euro
Jewel with First Times and SP3000 here: no way (!!) that the volume could be at 130/135. Above 60 it is already quite loud. The question now is where the problem lies.I have A&K 380 and LPGT TI
I was in Munich with my Jewel Aroma with First Time to listen SP3000 and Molnijr.
I listened 20 minutes sp 3000 SS and CU,but was disappointedly, find much better my LPGT TI,more neutral, transparent and natural.
Also volume I keep LPGT at 46/48 on 100 and sp 3000 to listen at same volume has to go to 130/135 on 150.
I have SP3k + Tsuranagi. But I haven't heard the 320Max or Mjolnir to be able to compare. All I can say is that the Tsuranagi provides quite a step up in sound quality. Prior to that, I hadn't quite realized how much of an improvement a good amp can make.how about adding a tsuranagi into the equation ? yes you would be stacking but i’d like to know whether sp3k (or lpgt ti or lp6-ti) + tsuranagi is comparable to molnjir if not better, considering only SQ ?
I never listened tsuranagi and I don't know.how about adding a tsuranagi into the equation ? yes you would be stacking but i’d like to know whether sp3k (or lpgt ti or lp6-ti) + tsuranagi is comparable to molnjir if not better, considering only SQ ?
Yeah, it shows up just like the internal folder in folder mode. SanDisk 2 terabyte solid state. I'll do a test later but I think it reads and is playable all within about 20 seconds.it works in folder mode ?
