nikp
- Aug 19, 2011
Yes they are worth it IMHO. Of course the word "expensive" goes to a certain limit.
Are expensive anything worth it?
Experience is priceless. When you're in your 80's and money doesn't matter anymore, all you can remember is the experiences you didn't have and the ones you did.
Very best,
Very best,
If you can live with your current rig, and don't feel envious of others, no.
Envy and lust seep into the forums after hearing how much better X is than x from those wanting to experience X. The scale of improvement based on price alone is a slippery road.
Living with a sound, then going back to your reference will point out any differences. If you can determine that difference by putting a price to it, you can then decide if it's worth it. To just say, is $xxx worth it, leaves too much unknown to determine worth.
As a hobbyist that has been incrementally improving my sound for 40 years, I will say that once I got into "Hi End Sound", I wished I would have bought the most I could have afforded each time and not cut corners to save a dollar. You may not be able to finance the entire rig in one go, but you can start with one component and build your way to completion. I have been doing this for the last couple years. I am waiting for DACs to standardize and competition bring down the ridiculous markups a "new and revolutionary" change demands. In other words, most high priced components are set based on what the designer/team thinks they can get. After competition determines the place of the "new and revolutionary" improvements, a value will be placed on it based on the customer.
So there is a value point but every consumer has to experience the options to make their own judgment. For me, there is better than average value based on sound alone but it might take you half your life to determine it.
Your happiness has no price tag. You either meet it or you don't, but know that just because it is an expensive set does not mean it will make you happy. I enjoyed my $30 used Sennheiser HD485 more than 99% of all the other headphones I have ever owned or even heard.
All the clarity in the world means nothing if it doesn't mesh with you.
