Do you know transmitter aptx adaptive with optical port? I got one vaorlo t9 but the delay in aptx adaptive is a nightmare.
aptX Adaptive / aptX Lossless USB Transmitters
- Thread starter mcnaugha
helmutcheese
That is the only one I know about.
Is the delay as bad with the other inputs?
I tried usb on pc and optical with tv in both cases the delay is about 300ms-500ms. When I change the codec to sbc or aptx hd the delay is a much smaller but not great like in kb9p.That is the only one I know about.
helmutcheese
What do you get on this:
https://nullvoxpopuli.github.io/latency-tester/
Creative BT-W5+FiiO FW5.
aptX Adaptive HQ around 300ms
aptX Adaptive LL around 165ms
aptX HD around 400ms
Fii0 BTA30 PRO+FiiO Neckband.
SBC around 240ms
AAC (will need use Intel AX210 as BTA30 PRO does not TX AAC only RX).
aptX around 200ms
aptX HD around 240ms
aptX LL around 54ms
LDAC around 200ms
Windows AX210+Soundpeats Sonic Pro
AAC around 270ms
AAC + Game Mode around 128ms
Creative BT-W5+Soundpeats Sonic Pro
aptX Adaptive HQ around 285
aptX Adaptive LL around 80
aptX Adaptive LL + Game Mode around (weird results, 45-100ms then settles around 80ms).
SBC around 240ms
aptX around 200ms
aptX LL around 54ms
LDAC around 200ms
AAC around 270ms
Tested on Sennheiser momentum 4What do you get on this:
I get around 300ms and in the low latency mode 165ms, aptX LL would be even lower and I can test that with my other devices later.
kb9p:
adaptive ll and hd (similar results) ~ 120ms
t9:
aptx hd ~150ms
aptx adaptive ~350ms
bt in my motherbord:
a2dp driver aptx and aptx hd ~ 250ms
sbc ~ 220ms
senhaiser btd 600
aptx adaptive ~95ms
My feelings:
kb9p the lowest latency. (not noticeable)
between aptx hd on t9 and my motherboard similar delay on my ears. (almost not noticeable)
t9 aptx adaptive very noticeable delay
I have just received my BT-W5 coming from the BT-W4 and am using it in combination with my H95, Qudelix 5k and M1 MacBook Air + PS5. I have noticed this intermediate crackling also with both the BT-W4 and BT-W5. Maybe the new FW update for the BT-W5 fixes the issue? The Mac app doesn't show an update though....I'm noticing a crackling sound / distortion intermittently with my KB9P output to either BT speakers of BT HP. It can be present for several hours then disappear for the next several hours. Wondering:
1. Is this interference from another device?
2. if so, what should I try to resolve it?
3. Would a Class 1 BT device like Creative BT-W5 be less prone to this?
Thanks for any suggestions!
Has anyone else experienced cracking noises when using the BT-W5 via aptX Adaptive?
I have no crackling at all when using the H95 via aptX HD and the Qudelix 5k via LDAC with my old Pixel 2XL running an Android 13 Custom Rom.
m-i-c-k-e-y
Using BT-W5 w/ my S23 Ultra. Have no cracking noise experience. Updated immediately to the latest FW via PC before using.
I just ordered a BT-W5, expect delivery in 7-10 days to U.S. Excited to see if it's range and performance exceed that of my KB9P.Using BT-W5 w/ my S23 Ultra. Have no cracking noise experience. Updated immediately to the latest FW via PC before using.
Seems like I am not able to update my BT-W5 :-/ The Mac app does not show an update. My old Macbook 2012 running Windows 11 in Bootcamp shows the update, but after installing it I am still on the same old version and its prompting me again to install the update....Using BT-W5 w/ my S23 Ultra. Have no cracking noise experience. Updated immediately to the latest FW via PC before using.
In its current state, the BT-W5 is unusable for me as it's making those sporadic crackling noises.
m-i-c-k-e-y
If feel you. Sorry to hear it Bro.
I read this thread and still do not know. Is it worth paying extra for Creative BT-W4 or BT-W5 instead of kb9p because of the sound quality with aptx adaptive?
helmutcheese
You are limited to 24/48 output with the BT-W4 (QCC3056) so may as well get the BT-W5 (QCC????) for the small difference in price (wait on deals) and you get the Low Latency Mode in addition to aptX HD.
If all you are listening to CD rips so 16/44.1 then it will not matter but the KB9P (QCC3040) for some reason (Firmware oversight) is missing 16/44.1 so less than ideal.
As being answer BT 5.3 chipset it may get additional feature in future FW but knowing Creative probably not.
Bw5 is 1/3 more expensive than bw4. I'm closer to bw4 or just to kb9p. I want to use for spotify, casual gaming, movies. Will be feel the difference in sound between the two transmiters (bw4, kb9p) ?
helmutcheese
Nobody but you can answer that once you hear both.
I did say wait on deal, they are both on sale right now and have an addition 10% off via a bank holiday voucher (UK store).
BT4 = £35.99
BT5 = £44.99
So yes, almost a 1/3 higher but it's not like a device costing £1000 vs £1333, it is £9 more.
BT4 = £35.99
BT5 = £44.99
I was hoping for feedback from someone who has used both.
Total: 48 (members: 10, guests: 38)
