Wait, Aptx Adaptive doesn't work on Windows? I've been using this adapter with my Fiio BTR3K on PC in Aptx LL mode but just ordered the Fiio UTWS5 for TWS and Aptx Adaptive. So you're saying Aptx Adaptive won't even work with this setup? Since the UTWS5 doesn't support Aptx LL, will it just default to Aptx HD or regular Aptx? If so, I just wasted my money... could have settled for the UTWS3.Avantree DG60P 5.3 USB receiver (2023 edition) mini review
Grabbed a used one off ebay for £15, so gave it a testing with my Windows 10 desktop pc + Nvidia Shield + LG C2 OLED TV
Pros:
-Works on Windows 10 plug and play, no driver required-Windows sees the device as a PC soundcard (not compatible with BT mice/keyboards etc)
-higher volume level then standard normal USB Bluetooth 5.0-5.3 Dongles that usually work with mice/keyboards since it runs like a usb soundcard
-Supports aptx adaptive (not on windows though due to no driver support) and aptx HD confirmed working (with A2DP windows driver) and green led flashes
-music and gaming mode (I believe this is a bit like higher quality BT codecs and lower latency BT codecs modes)
-Manual side button and led lights to indicate codec used and when connected, which is good since if its green its aptx hd etc
-Supports Ps4 (but no consoles test this)
Cons:
-Attenna is real glitchy I think you have to point it in the right direction and face it towards you or is it even working good enough?
-No Windows 10 software to check codecs or what BT mode or Codec is even being used but you have the led light on product
-Sorta works on Nvidia shield 2019 pro via USB sound mode, but so glitchy to connect took several attempts to connect to my PX8
BT headphones but the real issue is it switches to aptx-hd and its performance is terrible 1 metre away sound pops, cuts off so really it don't work well
I can reconnect using my TVs bluetooth and its stable again.
-Does not connect or work with LG C2 USB sound mode at all.
Basically the Avantree DG60p is fine for an Audio sound card for windows platform but remember it wont work with the A2DP windows software so no aptx-hd!
I bought this to see if I could get better lip sync or low latency support BT codec support for my TV to my headphones (which supports aptx adaptive), the Nvidia shield works with it but its glitchy and I question that attenna, even disconnecting and reattaching or moving it closer to myself it seems to buckle with the android based Nvidia shield so for my purposes its no good and back in the box.
I won't be recommending this device, the Asian KB8P/KB9P series or Creative BT dongles will probably be better and overall more useful but as with
anything its a trial and error at this point.
I prefer normal 5.3 BT dongles since it works with A2DP and gives me aptx-hd support on Windows 10.
