OzarkTom
- Jan 9, 2010
In loaned a friend of mine today the Eximus DP1 and the Dayens Ampino. He is stunned. He is getting the best soundstage and detail ever. He is going to buy one of each.
Just curious, what (if any) differences do you guys hear between opt/coax/usb inputs?
I haven't spent enough time with each input yet to really say what the differences are.
Those Cardas input covers look awesome!
Here is a discussion about Cardas Caps. Sounds like it is just some more snake oil that does not work.
http://www.audiocircle.com/index.php?topic=89032.0
Just came across these damper feet.
The prices seem reasonable as they are for a set of four.
http://www.hifi-ssc.com/Geraetefuesse_Pucks.htm
Click in the sidebar for the feet and don't bother with the English version.
Snake oil?
http://www.vibrationmounts.com/Store.asp?Page=Products8.htm
I sure would like to try this gel pad if the price was less, $85 each. You could cut it to four pieces and use it under your four feet on the components, but that is still cheaper than those stillpoints are. Watch the egg drop video to see how effective it is. It has to be better than the gel pads I am currently using.
The one I am looking at is the light blue one with the nubs.
There's a lot of stuff out there besides Stillpoints. Black Diamond Racing cones are $20 each. Audio Prism Iso Bearings are $70/3. Golden Sound DH cones are as little as $50/3.
