Android phones and USB DACs
post-10364943
Post #4,351 of 9,440
timothyll
Hey folks, been haunting a bit on this and similar threads around here... wondering if anybody's put together a reference on how much battery life we're getting using usb out of a phone to a dac/amp? - esp. without using a battery pack?
I mean, I know there must be a difference between the e18 and others like the hifimidy android dac, the uha-4 or dzero... but I can't seem to find much in terms of numbers.
thx!
post-10365388
Post #4,352 of 9,440
James1776
The best I can do is report I got over 8 hours playback using my Xperia through a Dragonfly and still had 25% battery left playing at 1/3 volume through in ear phones. I did not expect so much.
post-10365958
Post #4,353 of 9,440
swab
As a reminder, you don't have to use a USB hub in order to connect external storage to an Android device while using a USB DAC. You can use a Ravpower FileHub as mentioned here. HTH!
Sorry I'm a bit late to this but I have just been playing with various connectors, adapters, hubs etc with a tablet so I thought I would have a go with my Moto G after reading this.
I presume you ( swab ) are updated to the update to 4.4.2 ! ( Originally the Moto G worked with OTG attached drives but this was lost with the original 4.4.2 update. However, that has now been more or less sorted by a further update ).
I had confirmed that this new update was working but had not tried with a hub. I have a micro USB OTG Y adapter which allows further power to be supplied, but the first thing to realise is that this does not power the phone - it only powers the hub and items attached to the hub. I can confirm this is the case with a couple of hubs I tried with dac and drive attached. I played some tracks through the dac from the phone OK, but the drive was NOT recognised on the hub ( although it is recognised and can be accessed when attached directly to the OTG adapter ). So, it looks as though Motorola/Google have only partially solved the problem. ( My Samsung Note 8 can access the drive and dac and a mouse/keyboard all attached to the hub at the same time although the hub does need to be powered ). So this agrees with your findings with your hub experiments and it is unlikely to work unless there are further relevant updates.
It would seem that your best bet is some kind of wireless access to external files such as that suggested by Theogenes, above, and plug your phone directly into the dac via OTG.
Many thanks to you both for posting your suggestions/findings in relation to this. Further experiments with the unitek hub I referred to pretty much tallys with dynacampjims findings - the Moto G doesn't want to see the flash drive, and was fussy about how it would work with the DAC while connected to the hub. I do love Theogenes idea of using a FileHub, but I was hoping to attain a sub €10 solution as opposed to a €40 one.
As a longtime iOS iPod Touch user, where 50+ GB's of offline music was normal, I'm slowly adapting to the low cost Android smartphone/DAP/USB audio roadmap, a roller coaster ride with as many highs as lows, but with some magnificent scenery along the way. I might roll the dice on one of those cheap Android OTG USB Hubs and see if that works with the Moto G. However I am also sorely tempted by the FileHub + USB hard disk streaming TB's of lossless audio solution.
A quick question relating to the FileHub Theogenes : can your smartphone access mobile network internet while also connected to FileHub wi-fi network ? I seem to recall that could be an issue with wi-fi storage and smartphones...
swab
post-10366553
Post #4,355 of 9,440
dikkiedirk
Just connected a usb powered hub inbetween the DAC and RAY and now it sounds fantastic playing HIREZ 24bit FLAC truly budget setup, and not forgetting the brilliant mh1 headphones that are supplied with the RAY!
What is the RAY? Please point me to it.
Any changes of getting the iDSD Nano working with a Galaxy S4 and streaming player?
post-10366784
Post #4,356 of 9,440
cattlethief
Sony Xperia Ray,crackin wee phone same size as the Fiio x3 but half as thin can hold a 64gig sd card and play 24bit flac from its music player,sound is good but with otg to a good DAC sound is excellent!I picked up a new one from ebay last week for £70 complete with mh1 earphones.
post-10367886
Post #4,357 of 9,440
Zombie_X
Yo,
In the past USB audio worked with my HRT Headstreamer, but now it doesn't. I use a Galaxy S3 on JB 4.3.1. The audio is mute and skips in 4-8 second intervals. The DAC works fine on my computer but not on the phone.
post-10367966
Post #4,358 of 9,440
NZtechfreak
Actually it'll take a 128GB microSDXC card :)
post-10368018
Post #4,359 of 9,440
cattlethief
Even better!but then the sd card would cost more than the phone!!
post-10369255
Post #4,360 of 9,440
dikkiedirk
I don't feel like buying memorycards for phones and copying over my music. I rather stream it of my network. But UAPP has no streaming ability, eventhough it is the only app that can make my DAC sing upto 24/192. I can select a file in ES file manager and have UAPP play it, but this is rather limited. No artwork. And when a song finishes I have to manually select a new one.
iDevices work nices in this aspect with the 8player app.
Please mr. UAPP developer, give UAPP a proper file-manager with network access and streaming ability(DLNA,UPNP).
post-10371675
Post #4,362 of 9,440
Zombie_X
Too bad that app does nothing on my phone. Everything still skips and it mute.
post-10372345
Post #4,363 of 9,440
Norway
Norway
post-10372444
Post #4,364 of 9,440
dikkiedirk
Ditching my Android phone completely as it comes to streaming music to an external DAC.
Simply causes too much frustration.
Luckily you can use it as a phone........
post-10373685
Post #4,365 of 9,440
cattlethief
Stoner Acoustics UD110v2 DAC just arrived spared no time in getting the dual lock out,Muse the 2nd Law 24bit/96khz
has never sounded sweeter,and rig cost lest than a second hand X3,picke up another Ray from ebay for £50 might use than one for a phone
also plays 192 files but downsamples to 96.
Reactions: DanBa
Users Who Are Viewing This Thread (Users: 0, Guests: 9)
