pholcus1975
I'm using Neutron streaming from my Nas using SMB protocol, but gapless doesn't work.
Works fine when playing from phone folders.
Any tips?
Any tips?
Any tips?
Could it be 4g network is too slow to buffer? It was 16/48 flac file
Hi all.
I've been noticing that playing flac files on Neutron sounds more detailed than playing master quality files on the Tidal app. Do you have a similar opinion?
And, is there a way to play Tidal files on Neutron?
Is there a way to conserve energy while not degrading the sound with Neutron? I am currently running Neutron on DX220 and I can never pass 4 hours runtime
with 24bit/192Khz flac. I seem to get longer runtime using the native mango player. Is there any setting within Neutron to help with this?
Take look at this: https://neutronmp.com/faq/13-q-how-to-save-cpu-and-battery-when-using-neutron
Overall it uses more battery if you have oversampling function on, or the PCM to DSD. But that is normal.
With only EQ on it doesnt drain battery more than a normal player. In my experience at least.
For best battery, turn off the oversampling functions, if they are on. EQ and 64bit processing will not affect the battery life much.
You can experiment with different settings, like using only 2x oversampling instead of 8x, or if PCM to DSD dont use DSD128, try with 64. The higher the value, more battery will be used. Find best settings for you.
Im looking for a coupon or discount for the app, someone can help me?
